Sponsored by: Real Truck
Transmission Overheat Issue
Old Feb 9, 2008 | 01:47 PM
RedDawg's Avatar
RedDawg
I was driving my 04 F350 6.0 Powerstroke after it had been sitting for a week. In a very short period of time the "Check Gage" light was on and the factory trans temp gage showed maxed out in high. I shut down and left the vehicle and picked it up later. After about 10 minutes driving it did it again so I finished the way home and shut down.
I have 77k miles and am guilty of not changing trans fluid. I am assuming I have the 5 speed 5R as it has the Towing feature on the shift lever.
My question is, has anybody had a similar problem. I just picked up a new internal and external filter and fluid to change. Also, is the warranty 100k like on the engine.
Any suggestions are greatly appreciated.
Old Feb 9, 2008 | 01:59 PM
Beerstalker's Avatar
Beerstalker
Trans warranty is only 3 years 36000 miles on your truck (I believe it was bumped up to 5 years/60000 miles on the 2007s).
My first question is, did you check the fluid level?
Old Feb 9, 2008 | 02:02 PM
RedDawg's Avatar
RedDawg
I did check it and it was OK.
Old Feb 9, 2008 | 02:08 PM
Beerstalker
Did it smell or look burnt?
Old Feb 9, 2008 | 02:09 PM
RedDawg's Avatar
RedDawg
No, still looked red and no burnt marks on the stick.
Old Feb 9, 2008 | 02:13 PM
Beerstalker
It could just be a bad trans temp sensor. I'm not sure though, we'll see if anyone else has any more advice for you.
Old Feb 9, 2008 | 04:39 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
There have been quite a few temp sensor failures. That's probably what happened to yours.
Old Feb 10, 2008 | 11:20 AM
BillyBob69's Avatar
BillyBob69
I would go with the sensor as well. It happens. I have had new oil press sensors go out after two days. Replace the sensor and try again.
Old Feb 10, 2008 | 08:36 PM
RedDawg's Avatar
RedDawg
Thank you all for the info. I fought the Michigan cold and changed the internal and external filter. I flushed but did not measure in detail as recommended but got through it. Still had the problem and based on the last two replies I am hoping it is the sensor. Because it is 4 degrees out and I do not know where the sensor is I dropped the truck at a dealer (Trucks only) and will keep the KY handy.
This board has saved me many $$ and time so the rare trip to the dealer can be tolerated. Thanks again for the feedback.
Old Feb 10, 2008 | 09:05 PM
thedaddycat's Avatar
thedaddycat
The OEM gage is pretty much worthless as an indicator. I have DiPricol gages, the dash will read "Normal" within minutes of starting up, the DiPricol takes a while to even get into indicating range(100*F minimum). Same goes for coolant temp, but not quite as bad. In a case like this the gages serve as a cross check on the dash.
Old Feb 11, 2008 | 07:04 AM
Mark Kovalsky
It's in the pan near the internal filter.
Old Feb 13, 2008 | 11:34 AM
RedDawg's Avatar
RedDawg
Sensor
I took it to Motor City Ford, a truck dealer in Livonia, MI. It was the sensor and it was just over $300 for all the work. I am sure I could have done it but with the snow and cold I made the sacrifice. Learned a lot from all the posters so it was still positive.
Old Feb 13, 2008 | 12:25 PM
redford's Avatar
redford
FTE Leadership Emeritus
Hey, I'm old enough that I would seriously consider paying someone $300 so I din't have to lay on my back in 3 degree weather and change a sensor out. 30 years ago I would have done it myself but these days....not so much.
Old Feb 13, 2008 | 12:33 PM
BillyBob69's Avatar
BillyBob69
I hear ya on that one! Hell I even considered having someone change my alternator...but the wife cracked the whip....and I had to do it myself.
Old Feb 13, 2008 | 10:13 PM
thedaddycat
When she asks about how much you're spending on the truck, tell her that it's just money that you saved by doing the work yourself...
Yeah, I know. It doesn't work for me either......
