1978 - 1996 Big Bronco
AOD Transmission problems
Old Feb 9, 2008 | 01:03 PM
davebbgirl's Avatar
davebbgirl
I have a 1987 AOD transmission. Has a new TCI valve body, cluches, lip seals, bearings, pump, servos, etc. TV pressure is set correctly.
The problem is it shifts 1st to 2nd, but not into 3rd. Could I have the wrong length 1st/ rev servo?
Old Feb 9, 2008 | 03:06 PM
blue beast's Avatar
blue beast
http://www.lincolnsonline.com/tech/00080.html Are you sure it is starting in 1st and
not 2nd? I'm sure you would know but just to make sure.
Old Feb 9, 2008 | 05:07 PM
davebbgirl's Avatar
davebbgirl
AOD transmission problems
yes, when you take it from D to 1 it shifts into first gear.
Old Feb 10, 2008 | 10:42 AM
helirich's Avatar
helirich
I had the AOD on my old Bronco. I rebuilt it one time and it would not shift out of first. I thought I would drive it like that till the next weekend because I didnt have time to work on it. (I lived about 1 1/2 miles from work) One day, all of a sudden it shifted in to second. Once it did that, it wasnt so hard to live with and I was sick of working on it, so I kept driveing. It worked like that for about a week. Then, all of a sudden it shifted to third and OD. It worked good after that. I dont know what caused it. Some trans guys told me it may have been dirt. (new fluid and filter)
ChuckRob
19
Sep 25, 2014 04:52 PM
TonyJestis
Sep 24, 2013 09:02 AM
aode/w?
Jan 21, 2004 10:36 AM
