Manitoba / Saskatchewan Chapter Join Chapter, Leader: Fomoko1
New Ford ESP Programs
Old Feb 9, 2008 | 11:35 AM
Blackstock's Avatar
Blackstock
Former Vendor
Just to let you know...
There are some new programs we are offering, first is no money down no interest for 18 months on any Ford ESP.
New Diesel Care extended warranty till 300,000 kms
You can now buy used truck ESP even after the warranty has expired with an inspection from a Ford dealer.
Old Feb 9, 2008 | 12:23 PM
Fomoko1's Avatar
Fomoko1
Does this apply to an 05 F350/6.0 with 95,000 kms and if so at what cost?
96sherm's Avatar
96sherm
esp is extended service plan??
Old Feb 9, 2008 | 09:53 PM
Dustin1690's Avatar
Dustin1690
Yeah that sounds about right sherm that used truck esp sounds pretty cool
Old Feb 9, 2008 | 09:55 PM
Fomoko1's Avatar
Fomoko1
Waiting for a reply.....
Old Feb 9, 2008 | 10:39 PM
Blackstock's Avatar
Blackstock
Former Vendor
Sent you a PM quite a while ago, did you get it?
Old Feb 9, 2008 | 10:50 PM
Fomoko1's Avatar
Fomoko1
Thanks Jim, I just rechecked now and it`s there.....
Old Feb 10, 2008 | 04:14 AM
LaredoF350's Avatar
LaredoF350
Is this a new one or the one thats been out for about three months? The one that came then allowed you to buy some warranty. There were two options depending on whether you were under 3 years/60000 kms or over that.I think those were bit over $2000.
Old Feb 10, 2008 | 09:34 PM
LaredoF350's Avatar
LaredoF350
Morris, whats the details on this? is this something new, new or the same program that was out before Xmas?
Old Feb 10, 2008 | 09:37 PM
Fomoko1's Avatar
Fomoko1
I didn`t get that email so hopefully Jim will reply here.
Old Feb 10, 2008 | 10:24 PM
LaredoF350's Avatar
LaredoF350
I will be at dealer this week and will check into it and keep you informed!
Old Feb 10, 2008 | 10:26 PM
Blackstock's Avatar
Blackstock
Former Vendor
Yes you can now purchase Ford Extended Service Plans on your current vehicle even if the basic warranty has expired. Your vehicle must still fit within the guidelines and must be inspected at the selling dealer. For example, the top of the line Premium Care is available only on vehicles with 96,000 kms and less at time of purchase. If the vehicle is 2 years old you can purchase up to 4 years and 80 K. The next step down (Extra Care) you can purchase 4/80 for 5 model years old.
Also new is DieselCare and DieselCare Plus. Ford Extended warranty up to 5 years or 300,000 kms form original in service date. *** long as the vehicle (6.0L or 6.4L) is still under 5/160 warranty you can purchase this warranty without inspection.
Both programs can be financed at 0% over 17 months if the dealer has signed up and pays the admin fee. There are over 3,500 ESP available, so it is impossible to cover each one but the brochures and coverages are available here http://www.ford.ca/main/default.asp?...endedplans.asp
Hope that clarifies it at least a little bit
Old Feb 10, 2008 | 10:49 PM
Fomoko1's Avatar
Fomoko1
Any hints as to what the different levels of warranty might cost for a 05 F350/6.0 with
93,000 kms?
I`ve looked at the info supplied and haven`t found any rates yet.....
Old Feb 10, 2008 | 10:55 PM
LaredoF350's Avatar
LaredoF350
It will be a couple grand Morris
Old Feb 10, 2008 | 11:05 PM
Blackstock's Avatar
Blackstock
Former Vendor
An Extra Care ESP for an 05 with under 96,000 kms is
2 year 40K $2,005
3 year 60K $2,525
4 year 80K $3,025
Remember it requires an inspection and any covered component that is broken must be repaired at owners expence before warranty can be in effect. The Diesel Care and Diesel Care Total require no inspection. $1,480 and $2,465
DieselCARE Covered Components
ENGINE
• All internal lubricated parts
• Accelerator switch
• Camshaft position sensor
• Crankshaft position sensor
• Cylinder block
• Cylinder heads
• Electronic driver unit
• Engine control module
• Exhaust back pressure regulator
and sensor
• Exhaust pressure sensor
• Flywheel
• Fuel rail pressure sensor
• Fuel system (excluding fuel lines,
fuel tank, and frame mounted fuel
conditioning module)
• Harmonic balancer
• High pressure fuel injection
pump assembly
• High pressure oil regulator
DieselCARE Total Covered Components
• High pressure lines
• Injection pressure sensor
• Injectors
• Intake air temperature sensor
• Glow plugs
• Manifolds (intake/exhaust)
• Manifold pressure sensor
• Oil pan
• Oil pump
• Powertrain control module
• Seals and gaskets
• Thermostat
• Thermostat housing
• Timing chain cover
• Timing chain (gears or belts)
• Turbocharger/supercharger unit
(factory-installed)
• Valve covers
• Water pump
