Is this a new one or the one thats been out for about three months? The one that came then allowed you to buy some warranty. There were two options depending on whether you were under 3 years/60000 kms or over that.I think those were bit over $2000.
Yes you can now purchase Ford Extended Service Plans on your current vehicle even if the basic warranty has expired. Your vehicle must still fit within the guidelines and must be inspected at the selling dealer. For example, the top of the line Premium Care is available only on vehicles with 96,000 kms and less at time of purchase. If the vehicle is 2 years old you can purchase up to 4 years and 80 K. The next step down (Extra Care) you can purchase 4/80 for 5 model years old.
Also new is DieselCare and DieselCare Plus. Ford Extended warranty up to 5 years or 300,000 kms form original in service date. *** long as the vehicle (6.0L or 6.4L) is still under 5/160 warranty you can purchase this warranty without inspection.
Both programs can be financed at 0% over 17 months if the dealer has signed up and pays the admin fee. There are over 3,500 ESP available, so it is impossible to cover each one but the brochures and coverages are available here http://www.ford.ca/main/default.asp?...endedplans.asp
Hope that clarifies it at least a little bit
Any hints as to what the different levels of warranty might cost for a 05 F350/6.0 with
93,000 kms?
I`ve looked at the info supplied and haven`t found any rates yet.....
An Extra Care ESP for an 05 with under 96,000 kms is
2 year 40K $2,005
3 year 60K $2,525
4 year 80K $3,025
Remember it requires an inspection and any covered component that is broken must be repaired at owners expence before warranty can be in effect. The Diesel Care and Diesel Care Total require no inspection. $1,480 and $2,465
DieselCARE Covered Components
ENGINE
• All internal lubricated parts
• Accelerator switch
• Camshaft position sensor
• Crankshaft position sensor
• Cylinder block
• Cylinder heads
• Electronic driver unit
• Engine control module
• Exhaust back pressure regulator
and sensor
• Exhaust pressure sensor
• Flywheel
• Fuel rail pressure sensor
• Fuel system (excluding fuel lines,
fuel tank, and frame mounted fuel
conditioning module)
• Harmonic balancer
• High pressure fuel injection
pump assembly
• High pressure oil regulator
DieselCARE Total Covered Components
• High pressure lines
• Injection pressure sensor
• Injectors
• Intake air temperature sensor
• Glow plugs
• Manifolds (intake/exhaust)
• Manifold pressure sensor
• Oil pan
• Oil pump
• Powertrain control module
• Seals and gaskets
• Thermostat
• Thermostat housing
• Timing chain cover
• Timing chain (gears or belts)
• Turbocharger/supercharger unit
(factory-installed)
• Valve covers
• Water pump
