Edge Question
Old Feb 9, 2008 | 10:18 AM
zmartin's Avatar
zmartin
Edge Question
Will running an Edge reduce long term reliabilty in the 5.4?
Old Feb 9, 2008 | 11:04 AM
kd4crs's Avatar
kd4crs
I have had mine on my 04 F150 for 18k and it has been on my 06 for about 15k. No problems whatsoever.
Old Feb 9, 2008 | 11:22 AM
Blackstock's Avatar
Blackstock
Former Vendor
From a Ford dealers perspective, you should have no problem if you follow directions carefully. Run it in extreme (#3) without 92 octane and I can tell you from experience it causes terminal damage
Old Feb 9, 2008 | 11:25 AM
JimTex's Avatar
JimTex
I have 33,000 trouble free miles on mine.
Old Feb 9, 2008 | 03:55 PM
KevinAH's Avatar
KevinAH
I've had mine for about 70k miles. I use mine in #3 and #2 equal amount of time. I have had my share of problems but I can't say that I wouldn't have had the problems if I did not have the edge. My problems were typical of the model. Spark plugs, exhaust manifold leak, blown pcm(could have happened with or without).
Kevin
Old Feb 9, 2008 | 06:46 PM
dfishrmn88's Avatar
dfishrmn88
Did you mean 91 octane? The manual calls for minimum of 91.
Old Feb 9, 2008 | 07:53 PM
Blackstock's Avatar
Blackstock
Former Vendor
LOL yes I did sorry.
Old Feb 10, 2008 | 07:57 AM
Twinsdad98's Avatar
Twinsdad98
I'll be getting an edge when my truck is out of the shop. Even on level2 do you have run 91 octane? Or could I use the mid-grade 89? Just curious. Thanks.
Old Feb 10, 2008 | 08:08 AM
mbogosia's Avatar
mbogosia
Level 2 is actually an 87 octane tune.
Old Feb 10, 2008 | 08:13 AM
kd4crs's Avatar
kd4crs
87 is the minimum for level 2. If you run higher octane than that you can bump the timing to get a little more performance.
Old Feb 10, 2008 | 08:17 AM
Twinsdad98's Avatar
Twinsdad98
Unhappy
Thanks for the info on the edge. I'm sure all this is in the instructions that come with the unit. Now, I just want my truck back....
Old Feb 10, 2008 | 08:29 AM
veronese1's Avatar
veronese1
Engine longevity isnt going to be an issue with any of the programmers. The baseline tunes are conservative. The weak link is the 4r70/75e transmission.
From the front to the back....the converter, clutches, drum bands, etc. They are weak. For those that drive hard and tow with added HP/TQ from mods, spend the money on the transmission.
