Carb Problems
Old Feb 8, 2008 | 10:44 PM
antunez13's Avatar
antunez13
Carb Problems
I have a orange line coming off of the passengers side of the carb to a metal tube. The problem is the metal tube is rusted and broke, is this a vacum line and were does it go to. also were is the best placeto get a new one.
Old Feb 10, 2008 | 09:24 PM
woodbutcher05's Avatar
woodbutcher05
If you look on the exhaust manifold below and to the left of where the carb is mounted,there is a hole in the manifold for the steel line to go in,appearantly for heated air for the carb.
You can fabricate a new one using steel brake line available from any parts house.Just take the remains of the old one to get the correct size OD.
Leo
Old Feb 11, 2008 | 03:28 PM
antunez13's Avatar
antunez13
thanks got it working good know, i just ordered all the parts to lower it since its running good.
Old Feb 11, 2008 | 08:50 PM
javi2001's Avatar
javi2001
Tha's the line going to distributor vacum, there is a varible vacum on that line.
Get a used/damage old carb, remove one of those steel ports and install on your carb by pressing it in.
Old Feb 12, 2008 | 08:00 AM
n9lhm's Avatar
n9lhm
The port coming out of the air horn (high up on the carb) at an angle is the filtered air for the choke stove. It is the one that attaches to a metal line and runs down to the bottom of the exhaust manifold.
The distributor (timed) vacuum port comes out of the base of the carb and has a rubber tube all the way to the distributor, not a metal line, at least not from the factory.
Where exactly on the carb is the port you are talking about?
Old Feb 12, 2008 | 03:49 PM
antunez13's Avatar
antunez13
Its at the very top
Old Feb 13, 2008 | 03:09 PM
javi2001's Avatar
javi2001
Ok thanks for the clarification. N9LHM said it all...
