In tank mods really work....
Old Feb 8, 2008 | 08:30 PM
makomaker's Avatar
makomaker
Talking In tank mods really work....
I installed the ITP pre-filter kit and cut my vent and fill tubes. I did my first fill-up....worked great.
My opinion, the engine is a lot quiter. Have been thru 2 drive thrus and have not had to kill the engine once.
So all in all I think it worked nicely.
Note: when doing this mod...everything comes out nice and easy, but don't try to put the tank back in by yourself.
Old Feb 8, 2008 | 09:01 PM
Mike Norwood's Avatar
Mike Norwood
ain't that the truth. had to drop my tank soon after i bought the truck and re-install by myself. i like to have never got it back in there.
Old Feb 8, 2008 | 09:15 PM
justblowin'smoke's Avatar
justblowin'smoke
i've pulled three gas tanks and have had to put two of them back in buy myself
1 was easy it was a new one and was empty
2 i had help it was probably half full
3 was almost empty and was a 2wd gmc really low to the ground was probably the easiest
Old Feb 8, 2008 | 10:17 PM
Kwikkordead's Avatar
Kwikkordead
I have a transmission jack that works perfectly, even with a full tank.
Old Feb 8, 2008 | 10:26 PM
PaysonPSD's Avatar
PaysonPSD
I used a tip I read a couple of months ago. I ran tie down straps across the front and back of tank from frame rail to frame rail. Once I was ready it was real easy to lower the tank a little at a time until everthing was disconnected and then just lowered it to the floor. Raising it back up using the ratcheting tie downs was a snap. And I was able to do it by myself without a jack.
Old Feb 9, 2008 | 06:05 AM
papadelogan's Avatar
papadelogan
Snowboard season cometh..
I hadn't heard that one but I think I'll be using it soon!!! Awesome!!
Must be nice to have a metal tank!
Old Feb 9, 2008 | 09:11 AM
dpwilson's Avatar
dpwilson
ITP kit will be on my to do list. Glad it went well for you.
Old Feb 9, 2008 | 11:10 AM
wlihntr's Avatar
wlihntr
ok i have a question... i know the fittings on the fuel line tend to suck air into the fuel before the pump (i remember dan posting a pict. of it) which is one of the things the "intank" mods are supposed to fix. but if you haven't removed you fuel filter housing the fuel still goes into it, passes through the filter/water seperater and than is draw from the bottom...so how much air, if any is getting to the injectors? i guess one would have to pull the fuel line off the fuel rail and check it there
429 f-100
Jan 16, 2011 01:57 PM
stroken
18
Sep 29, 2009 01:48 PM
cooljman1
49
Jul 25, 2008 10:20 PM
brian42
17
Nov 28, 2007 11:46 AM
brian42
General Diesel Discussion
Nov 27, 2007 11:08 AM
