Harpoon Mod Question
Old Nov 27, 2007 | 11:07 AM
brian42's Avatar
brian42
Veteran: Navy
Question Harpoon Mod Question
I'm going to have my fuel tank dropped for some fuel line mods (ITP in-tank mod) and am toying with doing the harpoon mod (cut the two vent lines with a pvc cutter) so my tank will fill up without all the fuss.
My question is if anybody who has done this already has any problem with the diesel spilling out of the filler neck? Some of the stations I fill up at I will see the fuel froth coming up my filler neck when the pump shuts off with the longer vent lines. I would like to do the mod but not if I will spill diesel out of the filler neck every time I fill up.
Any feedback is appreciated. Thanks.
Old Nov 27, 2007 | 11:45 AM
ggirten's Avatar
ggirten
I cut the tubes on mine without any problems. I also made the filler plug bigger. Now I can use the big rig pumps. It rings up dollars like other stations rings up pennies. The downside I didn't think about is it takes more money to fill it up now since it has more capacity.
Old Nov 27, 2007 | 12:07 PM
RAMPAGE_F350's Avatar
RAMPAGE_F350
I cut both tubes and have had no issues spilling fuel out of the fill tube. It sure makes filling up nice and fast!
Old Nov 27, 2007 | 12:22 PM
F250_'s Avatar
F250_
Before I did the mod, hte foam you're talking about would shut off the pump and I would trickle in another 4.5-5.5 gallons before I would see fuel coming up the filler neck.
Now that I've done the mod, when the pump clicks off, I can barely get one more gallon trickled in before I see the fuel.
In neither case did I ever have problems with fuel gushing backwards out of the fill-tube.
Now that I am using B20, there is almost ZERO foaming. However, when the pump clicks off, I still have less than one gallon to top off the tank to where I can see the fuel.
Old Nov 27, 2007 | 02:54 PM
ron's power stroke's Avatar
ron's power stroke
no trouble with mine ether..if you haven't started yet...get a pair of ratchet PVC cutter for around 10 bucks..it will make cutting them tubes a lot easer and do a much a cleaner job..
Old Nov 27, 2007 | 03:31 PM
weekendwarriorfsw32's Avatar
weekendwarriorfsw32
Master of Strokes
Do you have to drop the tank to do this or not
Thanks
Nick
Old Nov 27, 2007 | 03:33 PM
ron's power stroke
Thanks
Nick
yes sir you do....link for harpoon is in mods and fixes link in my sig
Old Nov 27, 2007 | 03:53 PM
ggirten's Avatar
ggirten
While it is easier to drop the tank, I think you can pull the bed if you wish.
Old Nov 27, 2007 | 08:51 PM
truckeemtnfords's Avatar
truckeemtnfords
Veteran: Marine Corps
No problem with truck after the mod. Two gallons after auto shut off for fuel to be at base of cap and never a drop sloshed out.
Old Nov 27, 2007 | 11:19 PM
nhill2090's Avatar
nhill2090
In Nick's case it might be a little tougher to pull the bed off of his excursion
just giving you a hard time man
Old Nov 28, 2007 | 07:39 AM
ggirten's Avatar
ggirten
Not a problem. I should have read his signature to see what kind of vehicle he had.
Old Nov 28, 2007 | 07:46 AM
ron's power stroke
some guy's find out after breaking sockets on them big bolts holding the bed down..that its just as easy to drop the tank...
Old Nov 28, 2007 | 08:34 AM
ggirten's Avatar
ggirten
I had a brake line leaking behind the tank, so I had to pull it anyway. So while I was there, might as well work on the tank.
Old Nov 28, 2007 | 09:37 AM
nhill2090's Avatar
nhill2090
i am getting the Hutch in tank kit for xmas and i plan on dropping the tank and doing the harpoon mod as well, along with a few other small things i will hopefully get including the superlift truspeed, 3gauges and pod, and SS HPX line
Old Nov 28, 2007 | 09:45 AM
ggirten's Avatar
ggirten
WOW, you must have been a good boy this year.
