Rear Rotor Question
Old Feb 8, 2008 | 06:13 PM
Showpanther's Avatar
Showpanther
Rear Rotor Question
I am in the middle of replacing my rear rotors on my 2000 F250 PSD. The new one fits but the Ebrake Drum is thicker and it locks up the wheel when I tighten it up because the extra thikness is hitting on the dust shield behind it. Before I get out the grinder to trim the shield down a little I thought about asking you guys and gal if I should or do I have the wrong Rotors.
Thanks
Old Feb 8, 2008 | 06:26 PM
dryfly's Avatar
dryfly
sounds like wrong rotors.They have different one for the front,depending on which frontend you have.I geuss there could be different ones for the rear-end
Old Feb 8, 2008 | 06:30 PM
clintbonnie's Avatar
clintbonnie
If you have right hardware, everything should fit.. here is some instructions for rear brakes.. you might read thru in case you assembled something in error..
https://www.ford-trucks.com/article/...__Part_II.html
