Offroad & 4x4
tires
Old Feb 8, 2008 | 02:10 PM
twwtruck's Avatar
twwtruck
how much trouble is a sas
Old Feb 8, 2008 | 03:32 PM
MBBFord's Avatar
MBBFord
What ever you do, don't post this on pirate!
I can see the TTB D44 lasting with 38x15s if you don't ever use 4wd, but get on it once, and boom!
A solid axle swap would be the thing to do, but not always practical, b/c it is so expensive. The cheaper, faster way to get wheeling would be to not go as big of a lift, and run slightly smaller tires.
Old Feb 8, 2008 | 03:39 PM
captain p4's Avatar
captain p4
You could run 35s pretty reliably..
I'm going to have a solid 78 d44 for sale pretty soon if you're interested.
Old Feb 8, 2008 | 04:43 PM
rbloodhound's Avatar
rbloodhound
I have had no problems out of my ttb running 36" tsl's. I have replaced 2 tcases, 1 rearend, 1 clutch, several slave clyinders, and an engine. I have put the ttb thru hades and back. It does need work now. Ball joints need replacing and I found a bad ujoint in the passanger side axle. I do plan on a sas as soon as I get my parts and my shop built. This isnt a project that I want to attempt in the back yard. So untill then I am stuck with the ttb. If it brakes owell I have 2 more for parts.
I know I can't run the ttb and have the truck that I want. I want my truck to be the baddest truck around. I hope I will be able to write some of my mods off as advertising for my buisness. If I can look out. The sky will be the limit.
Old Feb 9, 2008 | 02:20 PM
twwtruck's Avatar
twwtruck
thanks for the help
someday
13
Sep 12, 2008 02:37 PM
Chucky D
May 27, 2008 02:46 AM
GKDave
Oct 31, 2006 10:03 PM
dshupp
2004 - 2008 F150
Sep 24, 2004 03:30 AM
AceTheLegend
1983 - 2012 Ranger & B-Series
Jan 17, 2004 08:17 AM
