Bigger Tires!!
Old Jan 15, 2004 | 01:53 AM
AceTheLegend's Avatar
AceTheLegend
Bigger Tires!!
What is the benefit of having bigger tires if there is one??
AceTheLegend
Old Jan 15, 2004 | 03:13 AM
CowboyBilly9Mile's Avatar
CowboyBilly9Mile
Larger diameter increases ground clearance (a + on 4x4); wider improves stopping distance and handling. But, since they are wider they create more wind drag ( - gas mileage ) and have more rolling resistance (more - gas mileage). Larger diameter tires tend to "float" over small potholes ( a + , esp on dirt/gravel roads) where small diameter tires drop into the hole easier, making the ride more noisy and jarring. Increasing tire diameter will improve gas mileage (well, for most people that don't burry their foot into the gas at every stoplight), but will detract from acceleration since you have effectively reduced (numerically) the axle ratio of the vehicle. Increasing the tire diameter will cause the speedometer/odometer to read less MPH and miles than you are actually doing/covering. This can be easily corrected however.
With this all said, only you can decide if the benefits are of value to you. Myself, I prefer ground clearance, safety, and a quiet, decent ride over a slight hit on my gas mileage since gas is cheap these days. BTW, I don't have a clue if your def of bigger means wider or taller.
Old Jan 15, 2004 | 08:32 AM
hotrodfeguy's Avatar
hotrodfeguy
I wonder how big of tires one can get to fit on the 2wd and 4wd square and round rangers respectively.
Old Jan 15, 2004 | 11:12 AM
AceTheLegend
i was kind of wondering about both! Just wanted to see any benefit if i had either!
AceTheLegend
Old Jan 15, 2004 | 12:58 PM
hotrodfeguy
Another benifit is lower engine speed/RPM for the same MPH with larger dia tires.
Old Jan 15, 2004 | 02:03 PM
CowboyBilly9Mile
Therefore improving freeway gas mileage.
Old Jan 15, 2004 | 05:04 PM
WXboy's Avatar
WXboy
I upgraded my tires just ONE size larger (only increased diameter 1") and the results are good and bad.
Good: Higher stance, better looks, and I never get stuck now.
Bad: Gas mileage has DECREASED, truck requires more distance to stop, acceleration is diminished, handling is spooky past 65 mph.
Before you upgrade tires, make sure you weigh the good and bad and decide if it's worth it. It's the classic battle of "form vs. function". Personally, I go for function (and safety) first. So when these wear out, I'm going back to factory tire size.
Old Jan 15, 2004 | 05:40 PM
hotrodfeguy
Well I just installed a set of 235/75/15's Have 4.10 rear gears
I think the reason you lost some mpg is because you already have smog gears They like 3.08/3.55 gears in those new trucks.
Old Jan 15, 2004 | 05:45 PM
AceTheLegend
So do wider tires give better gas mileage?
Old Jan 15, 2004 | 05:54 PM
99xlt4.04x4's Avatar
99xlt4.04x4
No Bigger tires give better gas mileage. Period. Wider tires dont because they are wider and catch more air. Taller dont improve mileage either. They put the truck up in the air more causing more wind resistance at freeway speed, and it is harder to get them rolling in city driving. Plus the extra weight of the extra rubber. But on the bright side, unless you go really tall (like 33's or bigger) there isnt going to be a big enough difference to worry about.
Braking does decrease with taller tires though. The brakes have to apply more force because of the extra leverage applied by the tires (physics). But really it is whatever you like and can afford.
Old Jan 17, 2004 | 08:17 AM
jamesbell's Avatar
jamesbell
Tires, Tires Tires everywhere. I had 245/75/16 as stock(recall tires), went to 265/75/16, now I have 255/85/16.
Lost some mileage with 265's, picked some back up with 255's, but I love 33 inch tires on stock rims.
AceTheLegend
Supercharger, Turbocharger, Nitrous Oxide & Water/Methanol Injection
Aug 25, 2006 06:18 PM
AceTheLegend
Aug 22, 2004 11:34 AM
AceTheLegend
Aug 14, 2004 11:42 PM
AceTheLegend
2.6, 2.8, 2.9, 4.0 & SOHC 4.0 V6
Jan 18, 2004 09:44 AM
AceTheLegend
Jan 15, 2004 08:14 PM
