1978 - 1996 Big Bronco
5lug conversion to 8lug
Old Feb 7, 2008 | 06:52 PM
mutang460's Avatar
mutang460
Hey does anyone know if u can buy a converter that will go from a 5 lug pattern to an 8 lug pattern... I know there is a conversion for 8 to 10.
If anyone wants to know why i'm looking for this setup, is because i'm getting some free tires, that actually go on a the army hummers, wheels and tires for cheeeeeeepppp but the wheels are 8 lug... please help
Old Feb 7, 2008 | 07:17 PM
andym's Avatar
andym
You could swap to 8 lug axles.
The front is easy, but there's no easy way to get 8 lugs on the rear.
Also make sure that it's a 8 x 6.5 pattern, not a metric pattern. Then you're just screwed.
Old Feb 7, 2008 | 08:13 PM
mutang460's Avatar
mutang460
yea thats why i was looking for a place that would makes a conversion because if they made one surely they made some off style type,,, and i got a feeling they are metric but not for sure yet.
Old Feb 8, 2008 | 07:15 AM
helirich's Avatar
helirich
I believe you can get a conversion/spacer ring to convert every posibility. The only problem is when you go smaller (from 8 to 5), sometines the brake parts wont fit in the new wheel. of course that is not the case for you.
Old Feb 8, 2008 | 08:29 AM
Kemicalburns's Avatar
Kemicalburns
what year bronco do you have?
Old Feb 8, 2008 | 11:24 AM
andym's Avatar
andym
My advice is never to run wheel adapters. They increase the stress on your lugs and can cause failure.
Old Feb 8, 2008 | 11:45 AM
helirich's Avatar
helirich
I think the stress on the lugs is the same for the same offset. Example, if I run ten inch wide wheels (the extra two inches is all to the outside) or eight inch wheels and 2" spacers, the stress is the same. Now if the wheel adapter is of poor quility, it may brake, but not the lugs/studs.
Old Feb 8, 2008 | 11:48 AM
Kemicalburns
i would say if he swaps the front d44 ends for 8 lug ends he should just go with a 3/4 or 1 ton rear axle
Old Feb 8, 2008 | 11:55 AM
helirich's Avatar
helirich
That would be the profered route. But that would be a whole lot more work and money than adapters.
Old Feb 9, 2008 | 12:25 PM
mutang460's Avatar
mutang460
I have a 79 bronco351 mod yea i was thinking about swaping rear ends but i really didn't want break down and do that.. but I do have a rear end out of a 86 f 250 just laying around but its huge
Old Feb 9, 2008 | 01:30 PM
aurgathor's Avatar
aurgathor
Adapters will also change the backspacing/offset, and unless you have no or very little fenders, you wold need to compensate for that by using a wheel that has more BS.
The only practical way is an 8 lug rear and 8 lug D44 ends for the front.
BTW, does the 8 lug D44 comes with bigger brakes than the 5 lug one?
Old Feb 9, 2008 | 05:27 PM
helirich's Avatar
helirich
It really doesnt matter which way he goes, he has to clear his fenders. Probubly with a 4" lift. But the back spacing is only going to change about an inch with adapters. I'm running wheels that are 7" wider than stock and I dont hit my fenders. That whole 7" goes to the outside. The bigger diff is always nice, but there is no real problem with the adapters.
Old Feb 9, 2008 | 09:25 PM
mutang460's Avatar
mutang460
i have 31x11.50x15 on it right now and the wheels are 15x10 i beleive, i'm not worried about having to lift it because the tires i'm trying to put under it will be 37 army tires and wheels so a lift is in the works for sure
