4x4 Problems
Old Feb 7, 2008 | 06:45 PM
PETE'S_6.0PSD's Avatar
PETE'S_6.0PSD
Bob you might have leak in you AC/Heater vacum lines too since they use the same system....check the dash vacum lines too....
Old Feb 7, 2008 | 06:46 PM
powerstroke1869's Avatar
powerstroke1869
where do i check my dash vacuum lines... my ac and vents work under normal conditions but as soon as i try to engage into 4wd with my esof its goes to defrost
Old Feb 7, 2008 | 06:50 PM
PETE'S_6.0PSD
ok than its you ESOF vac lines, dont bother with dash checking.
trace the lines from the hubs to vac solenoid, thats where is your problem....
Old Feb 7, 2008 | 06:52 PM
powerstroke1869
ok now my vaccum solenoid is on the passenger side right?
Old Feb 7, 2008 | 06:56 PM
PETE'S_6.0PSD
yeep you are correct....
Old Feb 7, 2008 | 06:57 PM
SpringerPop's Avatar
SpringerPop
I replaced each of my wheel-well vacuum hoses with 22-1/2 inches of 3/16" (4.8mm) SAE 30R7 fuel hose each side. Secured the ends with a tie-wrap.
It may last longer than OEM, and it fits perfectly.
Pop
