I have a 99 F-250 4x4 with the 7.3, my truck didn't come with keyless. I found a great deal on a complete ford remote and keyless entry system for a 2001 with the 7.3 for $ 100.00. I have been told that it will not work. Is there any way to make it work even if I can only get the keyless or is the problem that the computer will not communicate with it? The part number on the system is #1L3Z-19G364-BA
I'm not sure, but if your truck came with the key fob to unlock the doors, Ford sells an keypad that looks OEM (you almost can't tell the difference) that adheres to the door and sends a signal to unlock the doors when you enter the code.
If you are looking for the keyfob type of keyless entry, Ford also sells that OEM and it looks like the original fob. I had this for my 99 F150.
My truck didn't come with anything that why I am looking into the whole system. I called the stealership and they said they can't get the parts that I need for the 99 any more. Thank you for the suggestion though.
