Different tire sizes question
Old Feb 7, 2008 | 04:09 PM
wendell borror's Avatar
wendell borror
When I drove around with different sized tires, they were 60's and 70's era cars, no harm no foul. I don't know how it would effect the newer rigs now that they have abs. speed sensors and wheel sensors, tire monitors and so fourth.
Old Feb 7, 2008 | 04:14 PM
Greywolf's Avatar
Greywolf
Somehow - I just don't think he's driving THIS
Old Feb 7, 2008 | 04:21 PM
jason867's Avatar
jason867
I understand what you are saying (at least I THINK I do). Think of this whole thing like an equation.
you have driveshaft speed which equals 100%, then you have the 2 wheels that whose speeds add up to 100%, but it can change back and forth depending on how sharply you're turning in either direction. If you're going straight, it's 50% on each side.
So here's the equation under normal circumstances
Left tire speed + right tire speed = drive shaft speed
if you're going straight here's the values for the equation
left 50% + right 50% = driveshaft 100%
if you have a taller wheel on one side, it causes that axle to turn slower, which causes the other side to turn faster
left 40% + right 60% = driveshaft 100%
but, this is the same thing that happens when you turn. Which means either one side is going to spin some, or the other will drag some, or binding will occur and break something.
Please bear in mind that I am not trying to be annoying, or trying to prove anything, or mean or rude in any way. It's just that this makes 100% sense to me, and I feel you guys may not be understanding my thoughts on this.
If you still disagree with me after reading this, I won't press the point any longer, I promise.
Old Feb 7, 2008 | 04:29 PM
Greywolf's Avatar
Greywolf
I think you've got a solid grip on it, good man!
Now the thing is - IS THE AXLE on your truck limited slip or not? That's what we need to know.
If it isn't, then SURE! It may look funky, but you can get away with running odd sizes until you can get a replacement.
NON LIMITED SLIP AXLES are designed and intended for opposite wheels to run at different speeds, and they run like that constantly. They're built for it, and it's constant.
It doesn't hurt anything.
*To the best of my knowlege there is no sensor system installed in any Ford truck which eventually calls an error code that means:
"YO MAN! YOU TURNIN' LEFT WAY TOO MUCH - STOP IT!!!"
(For the Craftsman Truck Racing fans out there....)
Old Feb 7, 2008 | 04:43 PM
Greywolf's Avatar
Greywolf
Drive shaft speed divided by gear ratio=axle speed.
Axle(R)+Axle(L) divided by two=Axle Speed
Axle(R) and Axle(L) are percentages....
~QUOD ET DEMONSTRANDUM~
Old Feb 7, 2008 | 04:52 PM
jason867's Avatar
jason867
It is NOT limited slip, just standard
Old Feb 7, 2008 | 05:10 PM
Greywolf's Avatar
Greywolf
Excellent - then you should be alright.
It won't handle as nice as it might - the brakes may pull to one side. But it will get you to work until you can match things up again.
(Braking force is 75% applied on the front tires, 25% applied at the rear)
The difference should be very marginal.
Based on that, putting the odd tire out on the front is a bad idea....
(Do you follow that?)
Old Feb 7, 2008 | 05:56 PM
jason867's Avatar
jason867
once again, not to argue, but while the bigger wheel may pull to that side when braking, it also has more leverage in resisting the brake. So it may sort of equal out.
But let's not get started on that, my head's already hurting...lol
Old Feb 7, 2008 | 06:00 PM
Greywolf's Avatar
Greywolf
Not to worry -
I think for the time being you'll be alright, and won't even notice it.
but get it right soon, okay?
BOTTOM LINE: You're okay for now like that.
Old Feb 8, 2008 | 09:22 PM
bazzman1953's Avatar
bazzman1953
PS: DO NOT USE "FIX-a-FLAT"!!! Carry a plugging kit, and know how to use it!
I'd about guarantee that you've wrecked your rim with that stuff...
Can anybody guess why?
Old Feb 9, 2008 | 07:10 AM
wendell borror
You better check yourself partner, fix-A-iflat is a major sponsor here and they have a new set of thumb screws ha ha, "just kidding"!!!!!
Old Feb 9, 2008 | 07:14 AM
jason867's Avatar
jason867
what's wrong with fix a flat
Old Feb 9, 2008 | 07:00 PM
  #28
CougarXR02's Avatar
CougarXR02
you can run one size off for a shorter period of time. like weeks or months, just not years. This is how they can get away with the mini-spare.
On the front, yes, you may feel a slight pull to the small tire side, but nothing more than if you were down a few lbs. of pressure on one side. Or even on a road with a steep pitch towards the shoulder. I suppose you could run the small tire at 35 psi and the taller tire at like 29 and they'd be pretty close, while still at a safe air pressure setting.
Also, if the 195 is pretty worn and the 185 is almost new they will be pretty close. The tire gets shorter as the rubber wears off.
Old Feb 9, 2008 | 07:15 PM
  #29
Greywolf's Avatar
Greywolf
For one thing - it will pit your rims.
Most tire stores will also void a warrantee if they find that stuff inside a tire.
Old Feb 10, 2008 | 07:01 AM
  #30
jason867's Avatar
jason867
I could see it pitting chrome or aluminum rims maybe, but would it do it to steel?
I got the tire put on, it actually seems slightly smaller than my stocks. It does seem to pull ever so slightly to that side.
Thanks for all the help guys.
