turbo trouble
Old Feb 7, 2008 | 08:48 AM
bigugly'82's Avatar
bigugly'82
turbo trouble
hello,
I just bought a '91 f-250 extended cab 4X4 ,5 speed after 10 years of driving an '82 gmc with a 6.2 n/a. I'm just hoping my ford will be as reliable, its got to be able to pull my fifth wheel better as it has been turboed. Anyway how can I tell what brand of turbo it is? its located behind the stock air cleaner so when I first popped the hood I didn't think there was a turbo since i had never seen one with the stock filter still in place. plus the boost gauge doesn't work but looks like its all hooked up correctly. is it possible the turbo isn't working?
Old Feb 7, 2008 | 09:20 AM
catfish101's Avatar
catfish101
Pull the air intake of the turbo. Check the rotor shaft. See if it spins freely. That is it when it come to a turbo.
It takes heat to get a turbo wound up. The exhaust itself will get one to spin but what makes then really get going us when you give the engine more the fuel the exhaust gets hotter. Hot air expands and moves faster then cold air.
It is just like a turbine engine on a plain.
You may have fuel problem. Fuel filter, sucking air ect.
Check the boost gauge yourself. It may not be working. Use shop air or blow in the line and get somebody to watch the gauge. You can blow into it hard to bump the gauge.
Old Feb 7, 2008 | 09:53 AM
ghunt's Avatar
ghunt
If there's ANY leak in the line going to the boost gauge, it probably won't work, so that could very well be your problem.
Benchwrench
May 15, 2025 10:14 AM
vandy7.3
38
Oct 9, 2014 07:42 PM
AGE mechanic
Aug 18, 2011 07:47 AM
ghunt
Oct 21, 2007 12:56 AM
RDC F250 7.3
Oct 15, 2007 01:30 PM
