helpppppppppppppp
Old Feb 6, 2008 | 11:01 PM
smallmanthree's Avatar
smallmanthree
helpppppppppppppp
were is the relay for the hazard on a 99 ranger i cant get them to work
Old Feb 6, 2008 | 11:13 PM
Benaghetto's Avatar
Benaghetto
It should be in your fuse panel. I think it's tied in with your normal blinkers, that is unless they work properly then it is a seperate relay/flasher for the hazards.
Old Feb 6, 2008 | 11:22 PM
smallmanthree
thanks iv looked their and its not their it may be in the engine copmartment i have relays their that are not marked
Old Feb 6, 2008 | 11:43 PM
Benaghetto's Avatar
Benaghetto
They are in your distribution panel that's the black box next to your battery. Two, perhaps three relays should be across the middle. I believe the two on the right side are the computer and fuel pump. The third is the fog light relay. Swap the computer and fuel pump relays and see if it fires up.
