Hotwire
Old Feb 6, 2008 | 07:47 PM
1ford1's Avatar
1ford1
Hotwire
I have a 76 F100 that has been re-wired by the previous owner. I know the truck runs, but the wiring has been somewhat scavenged. What would be a quick way to get it to fire over and run, not drive? A hot wire to the coil from the battery? If so which post of the coil? I can short across the solenoid to crank it. Thanks
Old Feb 6, 2008 | 08:10 PM
tude's Avatar
tude
ive used this several times and worked great for my derby cars.
Old Feb 6, 2008 | 08:13 PM
Mil1ion's Avatar
Mil1ion
He only needs it to run for s short time.
attach a jumper wire from the battery to the Brown wire (I terminal wire) and turn the key or momentarily use a jumper wire from the battery to the S terminal of the battery
Old Feb 6, 2008 | 08:32 PM
matts77f100's Avatar
matts77f100
I used the remote start method to get an Audi running a while back. I had to bypass a bad ignition tumbler black box, and did so with a push button starter. A wiring PITA but doable.
Old Feb 6, 2008 | 08:39 PM
tude's Avatar
tude
the 1st time i used the wireing diagrams i posted it took about 2 hours. the last time i did it i think it took closer to 15-30 min start to finish. but i wasnt wiring any options up (headlights, radio, tail lights....) just made it so that it would run and move. yes it was in my derby truck (79 f250).
Old Feb 7, 2008 | 10:39 AM
bmuhlbach's Avatar
bmuhlbach
positive side of coil should be.
Old Feb 9, 2008 | 11:47 AM
rusty7983's Avatar
rusty7983
what about junkyard hunting/ removing the harness from a better truck?
Old Feb 9, 2008 | 01:01 PM
Mil1ion's Avatar
Mil1ion
76 was unique year for electrical systems especially the dash.
If swapping in a different harness make sure you identify which year it is and PLEASE note .....things changed along the way
I have a complete mint condition harness from a 75 in my garage but that would be going backwards.
Johnnymich
Jun 21, 2012 01:04 PM
mudder_lover
29
May 4, 2011 08:59 PM
hairyboxnoogle
Apr 27, 2011 09:56 PM
keyzdiver
Nov 27, 2007 10:41 PM
