Offroad & 4x4
leaf spring to coil adapter
Old Feb 6, 2008 | 06:25 PM
chrono4's Avatar
chrono4
Yeah, I dont know why you would take the time to cut the wedges off. From what you spend buying them, you recoup in the sale of the 44 to someone (with the wedges still).
Old Feb 6, 2008 | 07:26 PM
f150_514ci's Avatar
f150_514ci
i have done the dana 60 swap on my 76 f100 and this is how i did it first i went to the junk yard and got a dana 44 from another 76 that was bent and missing parts i got it for 20 bucks then i cut the wedges off (still welded to the old axle tube) went to the machine shop and had them boar it out to the same as the dana 60 ( now having 4 wedges) and you can use the stock radius arms fit everything in loose to your truck make sure everything is set up correct and spot weld in (i then took everything back to machine shop and had them fully weld it ( figured the are better welders than me ) for safety. bolted everything back up and no problems yet and has been done for 2yrs.i think there are pics in gallery but if not i can send you some
Old Feb 6, 2008 | 07:37 PM
chrono4's Avatar
chrono4
Nice work 514, I like it.
Old Feb 7, 2008 | 04:55 PM
Ford400Man's Avatar
Ford400Man
Originally Posted by 77f150got_sand
I did the 60 front and coil spring radius arm setup, check out my gallery for pics.
Just wondering,, When you swapped in the D60, did you use the 1/2 ton drag link, or the one with the D60? Pitman arm?
Old Feb 7, 2008 | 05:56 PM
77f150got_sand's Avatar
77f150got_sand
all the steering links are from the dana 44, it all bolted in to the 60 just fine, I did have to make the tie rod wider by threading it out at the adjuster sleeve 3/4 inch to achieve the proper toe alignment
Old Feb 10, 2008 | 12:51 PM
rbloodhound's Avatar
rbloodhound
Chrono. I have decided how I am going to swap in the 60. I am going to use cage arms. That seems like the easiest way. I have read several swap threads over on FSB. They are a little expensive. Around $750. The only thing that I will have to fab is the trac bar.
Still going to research this. I'm going to start looking for a 80 something srw F350 4x4. I'll take the running gear out and part the rest out.
Old Feb 10, 2008 | 12:55 PM
chrono4's Avatar
chrono4
Sounds like a way to go. Personally I just couldn't bring myself to dish out that much cash when I could build it for a fraction of that. But I guess I just get the joy out of knowing I made it... How long are the cage arms?
Old Feb 10, 2008 | 12:58 PM
rbloodhound
I am still open for suggestions. I had thought going leafs but decided against it. What to do what to do.
Old Feb 10, 2008 | 01:14 PM
chrono4's Avatar
chrono4
I'm going to just reuse my stock arms, cut, lengthen with some fat dom, brace accordingly and possibly bend for tire clearance. I'll more than likely just reuse stock brackets and bushings, but could easily got to a joint of some sort, but its just not in the budget. Figure I could do it for 50 bucks. Get some rattle cans of paint and make it pretty looking.
Old Feb 10, 2008 | 01:18 PM
rbloodhound
My problem is the ttb that I have to swap out. If I had a straight axle in a 79 I would find a 60 and install the wedges and use the stuff I already had.
This is what we are going to do in my friends 79 bronco.
Old Feb 10, 2008 | 01:23 PM
chrono4's Avatar
chrono4
Are you wanting longer arms for flex, or would stock s/a arms work fine for you? if stock would do, you could just get a set from a junk yard for cheap, and just use them as is.
Old Feb 10, 2008 | 01:33 PM
rbloodhound
Stock would work. I have thought about geting a set of stock 44 stuff and ordering a set of drop brackets. Then i could fab a trac bar. I dont need a lot of flex in Louisiana. I can always change it later if I dont like it.
I will have to look. I probably have everything but the 60 and the drop brackets. I have a lot of junked out trucks on my place in Mississippi.
plilikoi
Bronco II
Feb 3, 2010 03:19 AM
oem78
Jul 10, 2009 08:28 PM
Greywolf
Dec 18, 2003 07:46 PM
slimersoup
Offroad & 4x4
Jun 9, 2001 12:17 PM
