need transfercase help
Old Feb 6, 2008 | 11:14 AM
desperado10's Avatar
desperado10
Hello fellow ford fans I am a first time lister hopeing someone can tell me what T/C will fit in my 81 f250 now it has a BW1365 or 45 I have a 84 f150 with a np208 will this work thank you
Old Feb 6, 2008 | 11:29 AM
jareb03's Avatar
jareb03
What kind of transmissions are they? c-6, 5-speed, 4-speed, aod
Old Feb 6, 2008 | 11:33 AM
Franklin2's Avatar
Franklin2
Make sure the output for the driveshaft is the same. Some had a fixed yoke with a slip joint on the driveshaft, and some had a splined shaft on the output and the driveshaft slipped in and out of the transfer case itself.
Old Feb 6, 2008 | 11:34 AM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
Desperado,
You might have better luck asking this on the FTE: Clutch, Transmission, Differential, Axle & Transfercase board, here....
https://www.ford-trucks.com/forums/f...splay.php?f=69
Or use the search feature.....
Old Feb 6, 2008 | 12:18 PM
desperado10
the f250 has a granny 4sp the f150 has a 3sp with od
nowlin
23
Jan 12, 2014 01:07 PM
slayercr23
16
Aug 2, 2012 05:38 PM
wcbarker
43
Oct 7, 2010 12:38 PM
mccutcheon44
Nov 7, 2009 03:55 PM
spider7613
Jan 31, 2004 01:55 PM
