Sway Bar question
Old Feb 9, 2008 | 02:49 PM
chazman's Avatar
chazman
where can I get bushings for links and sway bar? 04 4x4 6.0 excursion with front and read factory sway bars.
Old Feb 9, 2008 | 03:04 PM
X_Hemi_Guy's Avatar
X_Hemi_Guy
I'd try these two links...Polyurethane stuff...
http://www.jcwhitney.com/autoparts/P...=group_listing
joe.
Old Feb 10, 2008 | 05:26 PM
fordcountry's Avatar
fordcountry
Originally Posted by i eat hybrids
Did u buy the truck new?
I bought the truck used from the same dealership that sold it new. The original window sticker was in the glove box when I bought it. VIN on the sticker matches the vehicle.
I'm guessing there must be a mistake on the original window sticker.
Maybe I don't have the front sway bar. Does anyone have a photo of the front sway bar?
Old Feb 10, 2008 | 09:36 PM
Stewart_H's Avatar
Stewart_H
Nah, you got the front sway bar. All Excursion and medium duty vehicles have them.
If you look, you'll see it running across the front, from side to side.
Stewart
Old Feb 10, 2008 | 10:48 PM
aortizexcursion's Avatar
aortizexcursion
Yeah, you definetaly have a front sway bar, however it is odd that you don't have a rear sway bar since the tow package included the towing mirrors and the rear sway bar. I don't know if this has been asked and answered yet (if it has, I'm sorry), but does the window sticker have the tow package listed as an option. Does the sticker also have the chrome tubular running boards listed under options also, because the lighted boards are standard equipment and it will probably have them listed under the standard equipment on the sticker.
One more question, So the Hellwig sway bars are larger than all the available Ford OEM sway bars?
Old Feb 11, 2008 | 08:05 PM
wylecoyote's Avatar
wylecoyote
I have the tow mirrors and do not have a rear sway bar. I am opting for the v-b code spring swap and the rear hellwig soon. If that doesnt stop the sway, nothing will..
Old Feb 14, 2008 | 11:31 AM
fordcountry
aortizexcursion, I will check tonight and answer your questions.
I got a quote for the F350 rear sway bars from the dealer. I'm able to get discounted prices through a connection. It think they are discounted!
quote for parts List/Net
Bar-Stab 69.90/52.43.
Retainer 16.80/10.50
Bush 39.50/24.69
Bracket 8.28/5.18
Link 33.60/21.00
Bush 9.58/5.99
Nut 15.00/11.25
U-Bolt 24.00/15.00
Total $513.22/$346.58
My local tax was added to the totals. So, is $346.58 for everything a good price? Or am I better off going with a Helwig?
Old Feb 14, 2008 | 11:36 AM
X_Hemi_Guy's Avatar
X_Hemi_Guy
You could get a Hellwig from JCWhitney for under $200 delivered to your door...at least the last time I priced one...JCWhitney runs coupon codes ALL THE TIME...
joe.
Old Feb 14, 2008 | 11:38 AM
fordcountry
joe.
Does it include all the links, bushings, u-bolts, nuts, mounting hardward, etc? I don't have the sway bar and would need to order everything. Thanks!
Old Feb 14, 2008 | 11:47 AM
X_Hemi_Guy's Avatar
X_Hemi_Guy
I had NO sway bar from the factory...
I received everything I needed to install the Hellwig...so YES it includes all you listed.
One thing I ran into that not everyone has...the factory U-Bolt that holds the lower rear shock mount is a 3/8" bolt. The Hellwig came with a 1/2" U-Bolt...well that new U-Bolt wouldn't fit thru the smaller hole...I ended up drilling the lower shock mount holes to accept the larger U-Bolt...
I also ended up simply REMOVING the rear shock lower bolt from the bracket to do the install...I got tired of fighting compressing the shock and trying to line up the holes...
Unbolt the rear shock lower bolt and bolt up the sway bar to the rear axle and then re-bolt the rear shocks is how I did it (different than the instructions).
so YES...you will get all the stuff you need with the Hellwig...
I have put ~13,000 miles of towing on the Ex since I got the Hellwig on...I am VERY satisfied with it.
Hope this helps.
joe.
Old Feb 14, 2008 | 12:40 PM
fordcountry
Joe, That helps A LOT! Thanks!!!
Old Feb 18, 2008 | 10:06 PM
aortizexcursion
Okay, I'm a bit confused, hopefully you all can help me. I need bushings for the front sway bar, how many bushing are there on the front sway bar all together and if possible can you all show me where I can possibly find black polyurathane bushings?
Thanks
Andre
Old Feb 19, 2008 | 01:37 PM
  #28
pdx02's Avatar
pdx02
so bottom line whereis the best place to get this for the best and LOWEST price?
olmstead96
Jun 22, 2015 02:05 PM
tbugher62
Oct 29, 2014 12:38 AM
6ohman2004
Sep 12, 2014 12:13 PM
diehardstroker
Mar 11, 2014 05:06 PM
pieman314
13
Jan 2, 2014 08:30 AM
