1978 - 1996 Big Bronco
vibration
Old Feb 5, 2008 | 08:09 PM
helirich's Avatar
helirich
vibration
I'm getting a vibration. It felt like u-joints, but my whole driveshaft was brand new (rebuilt) about three months ago. I checked out the joints anyways and they felt good. Then I felt the slip joint and it feels like it is loose. (in such a way that the driveshaft can bend just a little there) Have you guys ever heard of that? I took the shaft off and drove in four wheel and it seems to be gone. its kind of hard to tell because the transfer case makes some vibration at high speed. The shaft came from Autozone. Its lifetime, so I'm getting another.
Old Feb 5, 2008 | 09:13 PM
ubereal2's Avatar
ubereal2
Does it have a two peice drive shaft? What about a bad carrier bearing?
Old Feb 6, 2008 | 08:39 AM
Kemicalburns's Avatar
Kemicalburns
check the nut on the rear pinion. they somtimes work loose. but i would suspect its the driveline as well. the zone sells lifetime pieces of crap to be honest with you. I would find a local shop that deals in driveline builds etc..
Old Feb 6, 2008 | 08:49 PM
ubereal2's Avatar
ubereal2
I can't do the "Zone" part my self. Have actually taken the part "I removed" and they tell me............. "I HAVE THE WRONG PART"
Old Feb 8, 2008 | 12:06 PM
helirich's Avatar
helirich
I cant say I have a high opinion of the Zone either. But they did have the driveshaft when no one else did. It sure got me out of a bind. It would have been fun trying to drive home 400 miles on the front locked diff.
Old Feb 8, 2008 | 01:24 PM
blue beast's Avatar
blue beast
Grease that slip joint with the thickest grease you have on hand I got a ds from
a junkyard for a 85 and the slip joint has a grease fitting but my 86 ds doesn't have
it. You will have to pull it apart and grease it be sure to keep it in the same relation.
If it's got alot of slop from being dry and you drive off road or rough roads alot it
probably does need to be swapped out.
Old Feb 8, 2008 | 02:13 PM
helirich's Avatar
helirich
I dont drive off road so much anymore, but now and then. I live on a dirt road and when it rains hard, it gets rough until they grade it. I got a new one coming. No grease nipple and the boots are clamped on.
DNixe350
60
Sep 16, 2024 11:40 AM
majestek12
Mar 21, 2022 06:43 AM
McStein
1983 - 2012 Ranger & B-Series
Jan 11, 2017 11:31 AM
erichy
Feb 5, 2012 10:32 AM
HMA-169
22
Dec 17, 2004 01:34 PM
