Loud backfire after releasing accelerator...
Old Feb 5, 2008 | 05:52 PM
jschwen73's Avatar
jschwen73
Sorry if this is a redundant post...I did a search and found a similar topic but can't seem to find it now...anyway, just replaced the MAP sensor...that wasn't it...I seem to remember a post I read during my search about air flow being diverted from the Cat to the exhaust manifold to prevent backfiring? While changing my oil today I didn't notice any air hose to the cat...is there supposed to be one? Thanks in advance for any thoughts/observations/assistance...peace
Oh yeah, I forgot to say I've got an '84 F150 w/4.9L I-6 1-bbl feedback carb...all vacuum lines seem to be present and in good shape...just the above mentioned issue...thanx
Old Feb 6, 2008 | 06:52 PM
jschwen73's Avatar
jschwen73
31 views and nary a reply...c'mon people, throw me a bone here...guess i need to go searching again...
Old Feb 6, 2008 | 07:48 PM
fmc400's Avatar
fmc400
MSEE
First off, this is the first time I've heard of a carbureted engine using a MAP sensor, so if you could further expand on that that would help.
Anyway, Ford used an air injection system to dump fresh air into the exhaust to reduce emissions. However, if there is a sudden jump in intake manifold pressure with this setup, you'll backfire very badly. This is why there is an "air bypass valve" downstream of the smog pump that cuts off the air supply in this case. Typically you will have a check valve downstream of the exhaust manifold - it could be in the carb spacer plate with an exhaust pipe, or elsewhere. The check valve hooks to the smog pump via hose, and the air bypass valve splices into that hose between the two. The valve then connects to manifold vacuum. If you are missing this valve and your smog pump is otherwise hooked up you will experience this problem.
Old Feb 6, 2008 | 08:25 PM
jschwen73's Avatar
jschwen73
Thanks for the reply...yeah, I'm pretty sure it was a Manifold Absolute Pressure sensor that my mechanic replaced...he said if that did not fix the problem it was probably a carburator issue...I don't think he knows about the air bypass valve thing you mentioned though...that's the info i was looking for---I'll check into that next...thanks.
clayrog27
Aug 31, 2011 04:22 PM
matpasch
Sep 23, 2009 05:39 PM
ninetythreef150
Apr 4, 2008 07:36 PM
dm_lucky1820
Jun 17, 2007 06:45 PM
gearhed1971
Apr 8, 2007 08:10 AM
