CAT removal
Old Feb 5, 2008 | 05:22 PM
firebug's Avatar
firebug
CAT removal
I was told by the FORD dealer that if your truck has a CAT it has to have one. Something about enough exhaust back pressure to burn all the fuel. He also said if you remove the CAT you will have to reprogram the computer. Is any of this correct or was that just the dealer being politically correct.
Old Feb 5, 2008 | 05:23 PM
jimwilsonmasonry's Avatar
jimwilsonmasonry
i gutted my cat and my truck runs way better @281000 miles
Old Feb 5, 2008 | 05:34 PM
firebug's Avatar
firebug
you didn't have to do anything with the comp. How hard is it to gut one?
Old Feb 5, 2008 | 05:51 PM
2 stroke man's Avatar
2 stroke man
dealer is full of it lol
Old Feb 5, 2008 | 06:00 PM
scatgo's Avatar
scatgo
Get a delet pipe and put the cat away for inspection time.
Old Feb 5, 2008 | 06:03 PM
2 stroke man
i went to the muffler shop they gladly torched it and welded a straight through pipe
Old Feb 5, 2008 | 06:11 PM
tjbeggs's Avatar
tjbeggs
Legally if it came with one it has to have one. BUT I don't have one, my engine hasn't melted down, my PCM hasn't been recalled and it burns all the fuel it needs except when I want it to blow some smoke
Old Feb 5, 2008 | 06:21 PM
2 stroke man
well spoken TJ!
Old Feb 6, 2008 | 11:11 AM
mcdavidson's Avatar
mcdavidson
Right as always (well almost always, I am sure tim has been wrong once)...
Dealer needs to change the meds...
Old Feb 6, 2008 | 11:12 AM
tjbeggs's Avatar
tjbeggs
I have been wrong plenty!! Just ask my wife!
Old Feb 6, 2008 | 11:19 AM
mcdavidson's Avatar
mcdavidson
Ah yes, I know how that one works, even if you are right its still best to be wrong (or at least better for your sanity)... Gotta luv em though!
Old Feb 6, 2008 | 11:25 AM
scatgo's Avatar
scatgo
Any of you guys try to get through inspection without a cat?
Old Feb 6, 2008 | 11:46 AM
mcdavidson's Avatar
mcdavidson
Yep, NO GO, Visual sent me home (however I talked him into testing without it just to see, and passed no prob) it's the visual that kills ya, so I went home and came back 30 min later with my CAT AND MUFFLER on... have to have both to pass the visual here in I D HO...
Old Feb 6, 2008 | 11:56 AM
tjbeggs's Avatar
tjbeggs
An easy pass would be to gut the cat but the empty cat still causing poor flow with the chamber affect but you could sleeve the gutted cat. with either 3.5 or even better 4 inch pipe. just cut the cat body where 4 inch pipe will slide thru then weld the pipe to the body on each end. So pretty much you have an empty shell with a pipe going right thru the center.
Old Feb 6, 2008 | 12:01 PM
mcdavidson's Avatar
mcdavidson
HEY NOW Tim, that would be dishonest!
