Skipping
Old Feb 5, 2008 | 03:32 PM
mollikate's Avatar
mollikate
Skipping
I went on a short run this morning with light load. When i got there my truck was skipping so i pulled codes. got a 236 which i always get. When i started it back up there was no skipping and it run fine. By the time i got back home it was skipping again. Restarted and it ran fine again.
thanks
Old Feb 5, 2008 | 03:36 PM
Alpine6's Avatar
Alpine6
I would suspect a UVC harness issue. I can't remember what the 236 code is, but someone will chime in!
Old Feb 6, 2008 | 07:01 AM
mollikate's Avatar
mollikate
Aparantly No One Is Going To But Thanks I Will Check It
Old Feb 6, 2008 | 07:55 AM
F350-6's Avatar
F350-6
P0236 Turbo Boost Sensor A Circuit Performance
Do you have a chip/tuner?
  • DTC P0236 indicates a turbo boost sensor A circuit performance concern.
  • DTC P1247 or P1248 indicate turbo boost pressure was low or not detected.
  • Possible causes:
    • damaged MAP hose
    • low turbo boost
    • intake manifold or crossover tube hose leaks
    • damaged MAP sensor
    • damaged PCM
  • Inspect MAP sensor hose and manifolds for damage, leaks, restriction and misrouting.
Old Feb 6, 2008 | 08:17 AM
TurtleRacing's Avatar
TurtleRacing
PSD Addict
Have you done the UVC harness yet? If not, you might want to, mine did what you are describing a couple of times before it wouldn't run at all. i don't know about the code you are getting but the symptoms are familiar.
Old Feb 6, 2008 | 01:01 PM
mollikate's Avatar
mollikate
Please tell me more about uvc harness
Old Feb 6, 2008 | 01:11 PM
TurtleRacing
PSD Addict
There is a wiring harness under your valve cover that feeds your GP's and injectors,, the clip that holds the connector weakens allowing the connector to seperate and loose contact. Now don't ask me how it regains contact sometimes, but it does cause mine came and went several times. You have to remove your valve covers and put a wedge in the clip.
Check this out;
https://www.ford-trucks.com/forums/2...or-wiring.html
http://www.forddoctorsdts.com/articl...icle-05-10.php
Old Feb 6, 2008 | 01:36 PM
Alpine6's Avatar
Alpine6
When it starts running rough. Go up and unplug one side of the harness from one of the valve covers. If it doesn't start running rougher, that's your problem side. If it does, replug it in and unplug the other side. If it doesn't run any rougher, then that's your problem. If it does, your back to square one!
CoachRobb
1983 - 2012 Ranger & B-Series
Jun 28, 2013 09:31 PM
Fourbee
13
Sep 10, 2011 01:16 PM
kxstaffo
1978 - 1996 Big Bronco
Apr 16, 2011 12:08 PM
Jbrown8988
Mar 6, 2011 05:06 PM
beekermartin
1997 - 2003 F150
Nov 15, 2006 12:25 AM
