1978 - 1996 Big Bronco
skipping/ misfiring
Old Apr 16, 2011 | 10:11 AM
kxstaffo's Avatar
kxstaffo
skipping/ misfiring
85 full size bronco 351w.
Here is my issue. After driving 30 mins to and hour the bronco starts skipping/ misfiring and continues to get worst until it cuts off. If you wait and hour or 2 it starts back up and runs fine for 30mins to an hour and the skipping/ misfiring process starts again
Old Apr 16, 2011 | 11:58 AM
Anafiel's Avatar
Anafiel
Sounds like the ignition module is failing when it get's hot under the hood.
Old Apr 16, 2011 | 12:08 PM
greystreak92's Avatar
greystreak92
Welcome to FTE and the Big Bronco Forum. We'll do our best to get you the most accurate info we can.
Is your 85 fuel injected or carburated? With EFI, I'd suggest pulling codes and let the truck tell you whats ailing it rather than chasing things that MIGHT be the problem.
If its carburated, check carb settings particularly choke if you are dealing with a thermally activated version.
fordtruck661
Sep 30, 2013 01:32 PM
Shrink13
1983 - 2012 Ranger & B-Series
38
Jan 23, 2011 02:55 PM
Jbrown8988
Feb 21, 2010 07:22 AM
KW160
Dec 11, 2008 11:52 AM
beekermartin
1997 - 2003 F150
Nov 15, 2006 12:25 AM
