2016 wheels on 2005 Ex?
Old Sep 14, 2016 | 01:18 PM
LPD's Avatar
LPD
Hi, Does anyone know if a set of 18" 2016
F350 wheels will fit on a 2005 Excursion?
Thanks!
Old Sep 14, 2016 | 02:24 PM
WE3ZS's Avatar
WE3ZS
The lug nut pattern is the same as your EX but due to the suspension changes made to the Super Duty pickups (but not the EXs) in '05 the back spacing is different. To properly have those wheels positioned under an EX will require 2" spacers, and they should be hub centric just like your factory hub/wheels are. Depending on how good of deal the late model wheels are and where you buy the spacers it is possible to pay more for high quality spacers than the wheels.
If you are interested in OEM 18"s that can fit correctly without spacers, this thread has that info. https://www.ford-trucks.com/forums/1...excursion.html
Old Sep 24, 2016 | 08:22 AM
HiZ's Avatar
HiZ
Can you help Identify: I assume these are for coil sping front end!
Old Sep 24, 2016 | 08:27 AM
Jeremy05's Avatar
Jeremy05
They are, and you will need spacers to run those and have it look right.
Old Sep 24, 2016 | 08:31 AM
HiZ's Avatar
HiZ
Yup working with Google to identify
Old Sep 24, 2016 | 08:32 AM
HiZ's Avatar
HiZ
Thank you: appreciate the help with the year!
On for the King Ranch 04 wheels...........These do look nice. I like the spoke design vs the 5 big bars.
Thank you
Old Sep 24, 2016 | 10:53 PM
lt_crabby's Avatar
lt_crabby
Wheel spacers
These 2" wheel adapters from Fred's Single Wheel Spacers & Adapters For Most Truck Makes have worked great for my 20" OEM [~'07?] F250 wheels on 2001 Ford Excursion.
Futuresweets-10
Apr 6, 2010 11:23 AM
chris60
Apr 29, 2009 01:17 AM
wa97f250
Apr 9, 2007 03:13 PM
lapsdde
Jan 2, 2006 03:56 PM
