I had a guy work on my truck and he cut the wire for the Choke Thermostat.
Does it run to Starter Soleniod?
Needless to sat the truck won't idle to well this morning.
The choke is not opening
Thanks.
1980 F100 300
What did the guy do, cut the whole wire off? Aren't the two loose ends still there? A simple connector joint should make it right. Unless I missed something in the story.
