Crap... HELP.. OIL PRESSURE!!
When you first drain and flush, you're not going to have any pressure to speak of. This procedure will take awhile and a little patience. But just to run it to clear the pump will be fine. No, I don't like it either, but whatcha gonna do?
These pumps work through gears machined to close tolerance. Any sludge in there is going to cause pressure against those gears - so one way or the other (without removing the pan and the front part of the engine) you're going to need to crank that engine over. If you have a good starter and battery, then do as krewat suggested. But it needs to turn over good and for about 3 minutes. Otherwise the chemicals in the flush won't do much good.
