Antifreeze
Old Feb 5, 2008 | 07:43 AM
greedy737's Avatar
greedy737
Antifreeze
I have the green stuff, Going to replace with the same stuff.. Can I use any type of Green antifreeze??
Old Feb 5, 2008 | 10:10 AM
F350-6's Avatar
F350-6
Any of the big name brand green stuff should be fine. Don't forget the additive.
Old Feb 5, 2008 | 10:46 AM
clintbonnie's Avatar
clintbonnie
I would double check the container of antifreeze and look for that its meets Ford spec's, which is ESE-M97B44-A @ 50/50 mix. (got mine from Napa.. ) and like Chris says, add the SCA additive.. My manual says to add 4 pints if changing out the coolant..(maybe just 3 pints to start with). After running for awhile, check the SCA level with test strips.. Too much is not good, too little is not good.. or... change to the gold or red extended coolants.. no need for the SCA additive..
Old Feb 5, 2008 | 11:45 AM
greedy737's Avatar
greedy737
Thanks for the info. Getting the shell type from NAPA !!!
Old Feb 5, 2008 | 11:55 AM
just another truck's Avatar
just another truck
Dont want to Hi jack, but I didnt think the additive was always needed, The red stuff I just bought said no additives needed, so long as I cap off iwth the same stuff..
Old Feb 5, 2008 | 12:09 PM
StrokedRanchero's Avatar
StrokedRanchero
Look For Low Silicate, With The Ford Specification
Old Feb 5, 2008 | 12:22 PM
F350-6's Avatar
F350-6
Additives are only required for the old fashioned green coolant. You'll be fine with the red not using additives.
