Power Windows not working...
Old Feb 5, 2008 | 05:34 AM
ISUPhiPsi1052's Avatar
ISUPhiPsi1052
'05 SCAB XLT.
Went to open the windows this morning - nothing. Owner's manual indicates a 30A Circuit Breaker. "Circuit Breaker" to me inidcates that it's re-settable. Is that the case, or am I going to need to replace that item? If it's re-settable, is there a switch or something on the breaker itself?
Thanks in advance...
Old Feb 5, 2008 | 06:50 AM
f-150 on 22's's Avatar
f-150 on 22's
No, I am pretty sure that it will need to be replaced. Also, make sure your switch is not broken. My driver side switch started to feel weird to me and a few days later just stopped working. So, I took it apart to play with it and I wound up fixing it.
Old Feb 5, 2008 | 07:01 AM
ISUPhiPsi1052
Can't be the switch. All four windows are affected. I will try replacing the circuit breaker and see where it goes from there...
By the way, is it common for that part to fail?
Old Feb 5, 2008 | 08:59 PM
tomdoggie's Avatar
tomdoggie
Dont these trucks have a pw relay?
Old Feb 5, 2008 | 09:56 PM
MARC A's Avatar
MARC A
IT IS VERY COMMON FOR THE DRIVERSIDE SWITCH PANEL TO GO OUT ON THESE TRUCKS. I REPLACE THEM ALL THE TIME FOR PEOPLE AT MY SHOP. bUT WARRENTY DOES COVER IT IF YOU ARE STILL UNDER WARRENTY
Old Feb 6, 2008 | 06:47 AM
f-150 on 22's
Have you tried to roll down each window by it's own switch or did you just use the driver side panel? If you have only tried the driver side go and try each individual switch.
Old Feb 6, 2008 | 07:23 AM
ISUPhiPsi1052
I have tried each individual switch at all four doors. Dealer just called and it shows that there is no power going from the fuse box to the windows (but everything else is working). Sounds like this is going to be costly (no, not under warranty anymore)...
Old Feb 6, 2008 | 09:29 AM
MARC A's Avatar
MARC A
check for a loose connection on the back side of the fuse box where the wires go into the fuse. It is possible they might have jarred loose.
Old Feb 6, 2008 | 09:59 AM
ISUPhiPsi1052
I would hope that the dealer would have enough sense to check for a loose connection. Last conversation they were talking about pulling carpet, taking out seats, etc...
Old Feb 6, 2008 | 10:32 AM
Joe04F150's Avatar
Joe04F150
My driver side windows acts up some times.
Old Feb 6, 2008 | 10:49 AM
ISUPhiPsi1052
Got it back from the dealer. Corroded wire under the driver's side door sill. $288 bucks...
Old Feb 6, 2008 | 11:31 AM
Joe04F150's Avatar
Joe04F150
Wow...why so cheap...LOL!
Old Feb 24, 2008 | 02:28 PM
Twinsdad98's Avatar
Twinsdad98
22s- what did you do to fix your switch? My front pass switch is not working. I can operate the window with my driver's switch, but not the pass switch. Pisses me off since I doubt I've had someone in the pass seat more than half a dozen times!! Just wondering if it's more likely the switch or wiring somewhere..
