Sponsored by: Real Truck
tailgate not latching
Old Feb 4, 2008 | 09:49 PM
brwolfjr's Avatar
brwolfjr
My tailgate today would not latch properly. 3 closes for it to finally stay and that was with only the left side latching. Right side doesn't seem to be doing anything. There are no visible signs of dirt or debris. Do you think WD-40 would help or should I take the cover off and start looking around. Days are not long enough.
Old Feb 4, 2008 | 10:02 PM
Surge08's Avatar
Surge08
You can try but remove the access panel and check to see if the rods are returning to a park postion and not sticking
Surge08's Avatar
Surge08
Might even need a latch I just recalled that I have replace a couple
Old Feb 4, 2008 | 10:04 PM
brwolfjr's Avatar
brwolfjr
Broncochris,
I will give that a shot as soon as I get some daylight.
Thanks
Old Feb 4, 2008 | 10:05 PM
brwolfjr's Avatar
brwolfjr
what are the chances of both sides going?
Old Feb 4, 2008 | 10:06 PM
Surge08's Avatar
Surge08
50/50. could replace the one and in 2 weeks for example you may replace the other
Old Feb 4, 2008 | 10:08 PM
brwolfjr's Avatar
brwolfjr
with a bad latch, is there any chance of the gate opening while driving?
Old Feb 4, 2008 | 10:09 PM
Surge08's Avatar
Surge08
Yes, had a couple cases inwhich that has happened
Old Feb 4, 2008 | 10:13 PM
brwolfjr's Avatar
brwolfjr
i guess i will address the situation sooner rather then later. I would hate to think of loosing something out the back and someone getting hurt. Especially since I now know it is a possibility. Any idea how much a latch should run and how long to install. I only had the access cover off once and that was to secure the bed cap.
Old Feb 4, 2008 | 10:14 PM
Surge08's Avatar
Surge08
can remove the tailgate. prob increase fuel economy
Old Feb 4, 2008 | 10:21 PM
brwolfjr's Avatar
brwolfjr
i could remove it, then I have to tie stuff in. I think i'll just try to fix it. If that doesn't work I can always try the dealer. Thank you for all of the input.
Old Feb 4, 2008 | 10:23 PM
Surge08's Avatar
Surge08
Its a very easy fix just alignment is the fun part.
Old Feb 4, 2008 | 10:25 PM
brwolfjr's Avatar
brwolfjr
i just left some rep points for all of the help - have a great night.
Old Feb 4, 2008 | 10:27 PM
Surge08's Avatar
Surge08
you too and good luck. It should be a t27 or t30 for the access panel. goodnight
Old Feb 7, 2008 | 07:59 PM
brwolfjr's Avatar
brwolfjr
I wanted to share with everyone the WD-40 worked great. No need to disassemble, just gave each side a good shot.
1999er
Jul 24, 2014 05:27 PM
ejolliffe
Paint & Bodywork
Feb 18, 2011 09:17 PM
Mr. Green Jeans
Mar 30, 2010 07:14 AM
ErrorS
1978 - 1996 Big Bronco
Oct 24, 2009 12:23 AM
ellisos020
Apr 5, 2004 11:09 PM
