Transmission options
Old Feb 4, 2008 | 12:31 PM
powerstroker27's Avatar
powerstroker27
what can i do to upgrade my transmission besides just a torque convertor without either getting a performance rebuild or a whole tranny? I'm looking for something that can help to cure the 2nd-3rd sloppy shift problem since tunning doesn't seem to help much.
also can we get aftermarket valve bodies for the torqueshift?
Old Feb 4, 2008 | 01:56 PM
Frankenbiker's Avatar
Frankenbiker
The 2-3 will ALWAYS be a sloppy shift, due to what's going on during the shift.
Check what I wrote, here:
https://www.ford-trucks.com/forums/s...0&postcount=75
-blaine
Old Feb 4, 2008 | 02:36 PM
powerstroker27
-blaine
Yes ive read ur post but my concern lies with just how sloppy it is. it can't be good on the clutches for it to slip that much durring that shift. But so ur saying that no matter what part i get or how high end of a tranny i get here is nothing that anyone can do to fix this? seems like the torqueshift isn't as good of a transmission as what i thought it was.
Old Feb 4, 2008 | 04:10 PM
brentos's Avatar
brentos
If the tuning wont get rid of it, is it throughing any codes. Could be a solenoid acting up. There are no valves in our trannies to replace just solenoids.
Old Feb 4, 2008 | 04:35 PM
powerstroker27
nothing that the sct can pick up. and im still trying to ge ahold of matt to see if there is anything else he can do but as far as turning up the shift pressure its useless in the 2nd-3rd shift.
Old Feb 4, 2008 | 07:09 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
-blaine
Blaine,
You are right about this, except that the OD unit is in the front of the trans and the three speed portion is the rear half.
Old Feb 4, 2008 | 08:02 PM
zss42002's Avatar
zss42002
mine does the same thing i reprogramed my tranny. i performed a relearn and it helped a lil.
Old Feb 4, 2008 | 10:15 PM
powerstroker27
i did that this weekend and it seemed to help a little so now half the time it slipps really bad the other half it slams into gear and bucks a bit at first then takes off.
Old Feb 5, 2008 | 12:05 PM
powerstroker27
ok so if there are only solenoids then is there some kind of shift kit or line/pump upgrade that i could do to get better performance and atleast minimize the effects of the 2nd-3rd shift?
Old Feb 5, 2008 | 05:13 PM
Frankenbiker
Originally Posted by Mark Kovalsky
Blaine,
I don't suppose you've got an online picture of the innards of a 5R110 running around anywhere, do you? I'd like to see if I can sort out how it works.
-blaine
Old Feb 5, 2008 | 08:30 PM
Mark Kovalsky
No, I don't, sorry.
