Modular V10 (6.8l)
pcm
Old Feb 3, 2008 | 02:05 PM
bobc30_2's Avatar
bobc30_2
pcm
Hi Thanks in advance. I am new to listing on this sight. I have a f550 1999 ford gas motorhome vacationeer . I cant find the pcm error code wires to hook up to. if anyone knows where to look I would appreciate the help. Thanks Bob
Old Feb 3, 2008 | 06:09 PM
Johnny Langton's Avatar
Johnny Langton
There are no error code wires to hook up. Being a '99 model it's got OBD-2,and has a DLC(data link connector) that OBD-2 compliant code readers connect to. The connector is usually found right near your right knee under the dash.
JL
Old Feb 4, 2008 | 11:30 AM
jonrjen's Avatar
jonrjen
Bob, Welcome to the site. As JL said it will be OBII compliant. You could just run the motor home by most any parts store and they will be happy to bring a hand held reader out and check for any codes for you...FREE. What a deal.
Curious, what kind of motorhome is it that you have built on a F-550 truck?
Old Feb 4, 2008 | 01:37 PM
bobc30_2's Avatar
bobc30_2
Obii
Hi and thanks for your help. My motor home is a holiday rambler the model is a vacationer. Yes it would be a OBII I just didn’t no what to call it. I have looked under the dash on the left side and cant find it .I thought maybe some one would have a motor home that could tell me ware to look. I feel it miss at around 50MPH in the foot feed and steering wheel. Only has about 36000 miles on it but it a 1999 . I have changed the spark plugs. And Fuel filter. Chang the Transmission filter and fluid. Thanks Bob
Old Feb 4, 2008 | 01:46 PM
MARTYSTOWRIG's Avatar
MARTYSTOWRIG
i MAY THINK ABOUT INJECTORS, sOMEONE ELSE HAD A MOTORHOME ISSUE DUE TO A STEEL FUEL TANK AND I THINK IT WAS A 99 ALSO.
GOOD LUCK
Old Feb 4, 2008 | 04:55 PM
FortyFords's Avatar
FortyFords
The DLC connector is just to the left of the steering column. the plug is hard to see because it is turned sideways .
When changing your plugs did you replace the boots and use oem plugs ?
Also you may have a cop going bad.
Rich
Old Feb 4, 2008 | 05:08 PM
Big Orn's Avatar
Big Orn
Welcome to FTE, Bob!!
I'll go with FortyFords on the coil(s) being bad. You will not get a code most of the time and it saves time to go to your dealer and let them run a diagnostic on the engine. Those boots from the factory are made of sorry rubber that hardens and flakes, causing "spark leak" which is actually going to ground.
Old Feb 4, 2008 | 06:40 PM
bobc30_2's Avatar
bobc30_2
Thank for your help. I didn't change the boots they look good but i am going to. I bought a CAN OBD II U581 reader off e-bay . I well look harder tomarrow for the plug. And then when the can obd reader come in I can check it out. Thanks Bob
Old Feb 8, 2008 | 09:14 AM
bobc30_2's Avatar
bobc30_2
Hi Out there. I found my connector under the steering wheel cover on the right side it was put on the brace for the steering wheel. Could hardly get to it to move it. I got my scanner and checked it out shows no codes. So I wheel try the plug boots when it warms up her in Nebraska. Thank for
64ford
Apr 12, 2015 05:08 AM
bobkonaben
Mar 29, 2015 06:09 PM
kool4x4
New Member Introductions
Jul 15, 2014 02:23 PM
bob_m10
1997 - 2003 F150
Feb 28, 2004 07:37 AM
