Blower Motor Killing Battery
Old Feb 2, 2008 | 04:57 PM
Rockdaddy's Avatar
Rockdaddy
I came out this morning to find my 2001 Expedition dead. Once I put a charger on the battery I noticed the heater motor running all by itself (no key in ignition)<?xml:namespace prefix = o ns = "urn:schemas-microsoft-comfficeffice" /><o></o>
The blower will stop if turned off. <o></o>
Has any one heard of this? I thinking a stuck relay, but don’t know where the relay is located <o></o>
Thanks<o></o>
Old Feb 2, 2008 | 06:38 PM
antony25's Avatar
antony25
EATC or manual ac?
Old Feb 3, 2008 | 08:12 AM
cdolor's Avatar
cdolor
If it is a EATC unit my vote would be leaking windshield and a wet GEM. Happened to mine. The running blower seems to be the most common result of a wet GEM.
Old Feb 3, 2008 | 01:01 PM
Rockdaddy's Avatar
Rockdaddy
No EATC, manual temp. control
Old Feb 3, 2008 | 01:27 PM
antony25's Avatar
antony25
Most likley a stuck relay located next to the flasher under the LH side of the dash. Turn on the flashers and look for where the clicking is coming from then pull relays until you find the correct one. The blower relay is not in the fuse box.
Old Feb 3, 2008 | 01:43 PM
Rockdaddy's Avatar
Rockdaddy
*FORD SPECIAL MESSAGE #15773 VARIOUS ELECTRICAL CONDITIONS RESULTING FROM WATER INTRUSION INTO THE GEM/CJB
SOME 1997-2002 EXPEDITION AND 1998-2002 NAVIGATOR VEHICLES MAY EXHIBIT
VARIOUS UNUSUAL ELECTRICAL CONDITIONS, INCLUDING BUT NOT LIMITED TO: FRONT OR REAR BLOWER OR EATC STAYING ON WITH KEY OUT OF THE IGNITION, RADIO STAYING ON AFTER DOORS OPENED AND KEY OUT OF IGNITION, WIPER CIRCUIT FAILURE CODES, AND MULTIPLE SYSTEM WARNING LIGHTS WITH 'SHORT TO POWER' OR 'LOW BATTERY VOLTAGE' DTCS. THESE SYMPTOMS MOST OFTEN OCCUR AFTER A RAIN OR SNOW.
THIS MAY BE DUE TO GEM/CJB WATER INTRUSION RESULTING FROM A WINDSHIELD WATER LEAK. TO SERVICE, REMOVE THE GEM AND CJB FROM THE VEHICLE, SEPARATE THEM AND INSPECT FOR WATER CONTAMINATION OR CORROSION. IF FOUND IN EITHER COMPONENT, REPLACE BOTH COMPONENTS AND COMPLETELY RESEAL THE WINDSHIELD.
EFFECTIVE DATE: 04/05/2002
Old Feb 4, 2008 | 10:34 AM
01expedownr's Avatar
01expedownr
if it does it when it rains or snows its a cracked windshield or bad seal around same - causing GEM to go nuts... reseal windshield. Mine did same thing.. took me months to figure it out!
digitaldemon
Jan 28, 2013 03:19 PM
SC65F100
Jan 14, 2013 04:45 PM
RV-Dean
Feb 26, 2008 04:38 PM
fly4fun35
16
Feb 20, 2008 10:17 AM
loweryster
15
Apr 26, 2006 09:26 AM
