Need help with odd sound
Old Feb 2, 2008 | 03:35 PM
BNGOD's Avatar
BNGOD
I have a 03 that has started to make a "weep weep" sound at low speeds 10-35mph. It almost sounds like something rubber squeaking. The dealership checked it out and removed the drive shaft and checked all the joints. The odd thing is that is doesn't seem to change in frequency with speed that I can tell.
I was hoping that someone else has had a similar problem or had an answer.
Old Feb 2, 2008 | 05:10 PM
wb6anp's Avatar
wb6anp
worn brakes maybe don't know if these trucks have a warning tab to warn of low brake pads.
Old Feb 2, 2008 | 05:19 PM
drakul20us's Avatar
drakul20us
could be just the shocks squeeking
Old Feb 2, 2008 | 11:14 PM
sedwardson's Avatar
sedwardson
Mine had a similar sound at low speed and it turned out to be the front driver side caliper not retracting all the way. They replaced a boot, cleaned everything up and chamfered the brake pads. No more noise.
Old Feb 4, 2008 | 06:50 AM
BNGOD's Avatar
BNGOD
Thanks for the inputs. I am taking it back to the shop today and have them check it over again. I will ask to have the brakes checked a bit closer this time.
Old Feb 4, 2008 | 02:32 PM
sedwardson's Avatar
sedwardson
here's the break down of what they did to mine: replace caliper slides, anti rattle clips and pin boots,
86bullnose95
Oct 21, 2013 09:35 PM
Reidicus
Oct 7, 2012 02:03 PM
TPM
Jan 12, 2009 05:51 PM
Fraalan
Feb 17, 2007 03:18 PM
FEmtnmax
Jan 10, 2006 11:38 AM
