400 rebuilt
Old Feb 2, 2008 | 03:31 PM
mustang81's Avatar
mustang81
400 rebuilt
Yesterday i install cam xe-256H, rebuilt 400 crank .010 under on main and rod and 4 pistons .030 over. I install pistons 1,3,5 and 7. Tonight i'm gona install 2,4,6 and 8. My deck hight is .090. My pistons are rate .092 but the machine shop deck my block .002 because 3 sleeves were drive in. I don't have my timing chain yet. Should i go with comp cam for the timing set cause i got the cam ? or Elderbroock ? I know i have to set at zero. But witch brand does ?
Old Feb 2, 2008 | 05:24 PM
hollenjoe's Avatar
hollenjoe
any brand should be fine, a double roller chain will rock and do you have your heads decked too?
Old Feb 2, 2008 | 09:29 PM
havi's Avatar
havi
I'll have the Roast Duck
nice work. Hope to see that thing in the mustang.
Old Feb 9, 2008 | 05:59 AM
mustang81's Avatar
mustang81
Not rebuilt the heads yet. I want 3 angles valve job, new valves and valves steam. The aussie head will just be shave to be plain. I might work my exhaust side with a little porting. I'm gona have to cc's those heads.The comp ratio is arround 9.4 with this set-up. Silvolite cast-aluminium piston .092.
Nick-1973-ford
Mar 5, 2017 06:38 PM
Joel Cassell
26
Feb 2, 2017 02:18 PM
mustang81
19
Jan 23, 2013 09:14 PM
79Montanalariat
Apr 22, 2012 09:59 PM
cdawley4
13
Feb 24, 2011 07:31 PM
