hello I,m kinda new to here, you guys helped me out with a e4od problem many thanks. want to know what year of pedal assembly would work in my 93 f-350 crew cab 2wd. 7.3 tired of having these trans problems.any info would be appeciated.
Two major styles are manual clutch and hydraulic clutch. If the tranny you are choosing is the 5 speed zf, then I believe it requires the hydraulic setup, with the master cylinder.
I would like to make it as o.e style as possible so I think it would be hydrolic, if any body knows what years to look for downer truck. and if the pedal ***. would be the same in a half ton. I also heard that the trans. has to be from diesel, gas zf,s were different is this correct?
ZF for diesel has a different set of gear ratios. I don't know on the bolt pattern, I thought they were the same. You will need a hydraulic clutch setup to complete the install. Also the ZF uses a Dual-Mass flywheel that some here have swapped out for a "normal" flywheel. Search the forum for their experiences on that. I am contemplating swapping out my T-19 for a ZF as well an have looked into this a bit. Some of the clutch system pieces may be dealer only but you should be able to source most of it at your local parts house. Good luck!
Thanks guys for the info. really like my truck if it wasn't for the auto. my other truck has the 5spd and have had no problems in 485,000. youall are great.
