ABS fuse
Old Feb 1, 2008 | 07:07 PM
straightsixer's Avatar
straightsixer
ABS fuse
My abs light came on this morning a few moments after startup and stayed on. thought I would check the fuse first but looked in the fuse panel under the hood and there are two empty places labeled ANTI-LOCK BRAKES, weird cause this is the first time the light has come on so I'm assuming the abs worked before today.
Old Feb 1, 2008 | 07:14 PM
quicklook2's Avatar
quicklook2
13 and 15 need fuses for abs according to owners manual.
13=15 amp
15=20 amp
Old Feb 1, 2008 | 07:53 PM
straightsixer
Thanks, but my fuse box is the one with 5-relays along one side. I think you are referring to the box with the turn signal flasher in the corner.
Old Feb 1, 2008 | 08:02 PM
quicklook2's Avatar
quicklook2
that is why giving your year and model is helpful.
