my cornering lamp broke when i hit a trash can, and now i am having trouble getting the headlamp assembly detached from the body so i can replace it, the technical manual is no help so i'm hoping someone on here has had to do this for a 94 before and can tell me what to do, its a matter of not being able to find the screws or bolts i am supposed to take out. thanks in advance - Nate
The corner light is a pain, I had to pull the bottom 1/2 out and use a ratchet wrench. I think if you take that side grill out, the one that goes around the headlight the lights should come out.
........first off .....WELOME to FTE, Nvaeth . . . . . .
......seem's reading that link, ONLY help's if changing the bulb's; NOT for what this person on this thread is in need of >>>>> to REMOVE the Headlamp assembly.........
are 2 # 10 nuts......those and the top screws hold the headlight door (casing you called it) on. I used a 1/4 drive rachet with a deepwell socket and put a tad of grease in the socket to hold the nuts.
After those are off you can pull the headlight door out and replace the bulb
that is from that post and tells how to take it off.
maybe you have a better suggestion on what he should do.
are 2 # 10 nuts......those and the top screws hold the headlight door (casing you called it) on. I used a 1/4 drive rachet with a deepwell socket and put a tad of grease in the socket to hold the nuts. After those are off you can pull the headlight door out and replace the bulb
that is from that post and tells how to take it off. <<<<< ??????
........YES, i would have a better suggestion of, but, sorry to say i have NEVER had the attempt to bother with taking off the whole Headlight from either side, YET........... ........all i am pointing out is that this guy is not going to be able to get the whole headlight setup off with what that link has to say, at least in from my opinion of; IF you were offend'd from those word's, sorry about's that q2, was NOT meant to be an Offensive remark... ....now, to get back on topic of, i am reasearching now trying to find something to help this guy out......
............much BETTER of a link = for explaining to this New guy for help........thx, quicklook2 . . . . {you got there before me for me typing out that last post to ya.......LOL }. . . . .
