misterious fluid leak
Old Feb 1, 2008 | 04:46 PM
fash's Avatar
fash
hey there,
can anyone advise me on an issue with my truck. I was doing the front break lines. Had the tires off, truck on jackstands. I needed to turn the wheels, so i put it in neutral and turned the steering wheel. I heard a squishing noise ant the floor was covered in power steering fluid. The vehicle wasn t running. I couldnt find a leak in any of the lines. Not sure where its coming from. I know its power steering fluid because the reservoir is now dry. Can anyone help
Also i cant crack the bleeder screw on left caliper. I used a vacuum pump on the right side. Breaks seem fine. Could this have bled both sides
Old Feb 1, 2008 | 04:53 PM
quicklook2's Avatar
quicklook2
another post is discussing this also, if engine is off and you turn wheels the power steering pukes fluid.
i have seen it happen to gm and ford vehicles.
Old Feb 1, 2008 | 05:22 PM
fash's Avatar
fash
i saw that after i posted. Any advise on the air bleed screw
Old Feb 1, 2008 | 06:13 PM
quicklook2's Avatar
quicklook2
soak it for a few days.
if brakes work thaen maybe you should not mess with it.
do they pull or feel soft?
Old Feb 1, 2008 | 06:41 PM
fash's Avatar
fash
no not really, they acually feel better than before. weve had alot of snow here today so i havent had a chance to test it on dry pavement yet. but they seem very responsive
Old Feb 1, 2008 | 10:55 PM
kcb37's Avatar
kcb37
If it breaks even now, and they don't pull or anything, leave it alone untill you need to do something to it.
It can be easy to break more and have to spend more.
