Radiator help
Old Feb 1, 2008 | 04:15 PM
woodstock08's Avatar
woodstock08
Radiator help
I think my truck needs a new radiator becauese it has a pinhole that will close up with stop leak but if I get on the truck hard it will start to leak and then close up again later. I work in a body shop and in one of our books I can get a new one for 175 so is that a good price or do I have better options.
Old Feb 1, 2008 | 07:17 PM
fmc400's Avatar
fmc400
MSEE
You can have the leak soldered shut for under $20. Take the radiator out and inspect it. If it just has one pinhole leak and is otherwise in good shape, you're better off repairing your current one. If you find that it has already been patched in multiple places, you're better off just getting a new one because it's getting old. You can tell where it has been patched because the metal will look "melted" and the fins around the patch may be bent. Also, if there is any discoloration on any of the patches, they're getting ready to leak too.
Old Feb 1, 2008 | 07:43 PM
woodstock08
mine is all corroded and green can i clean it
Old Feb 1, 2008 | 08:09 PM
4starcstms's Avatar
4starcstms
Radiator is made of Copper and brass, the Copper turns green when exposed to the elements. Take it to a radiator shop. Let them test it for ya. They should be able to give you a honest answer if its worth fixing or not.
Old Feb 1, 2008 | 08:32 PM
73f100shortbed's Avatar
73f100shortbed
You did not state what truck or motor you have, but I paid around $150 from Autozone for mine for a 302
Old Feb 1, 2008 | 08:36 PM
woodstock08
Its a 360 so is 175 ok
Old Feb 1, 2008 | 08:50 PM
73f100shortbed
Sounds ok. I looked on autozone and looked up 73 F100 with a 360 and their price depending on which one you need was $140-400. I would say $175 is a decent price.
Old Feb 1, 2008 | 09:31 PM
mando jake's Avatar
mando jake
I've got a couple good used ones that I'd sell ya for $25+shipping. Was saving, but I got me a 4-core. Is your truck Manual transmission or Auto?
Old Feb 1, 2008 | 10:15 PM
woodstock08
manual what kinda shape are they in
Old Feb 1, 2008 | 10:16 PM
woodstock08
"good" never mind that question could you send me some pics
Old Feb 1, 2008 | 10:34 PM
mando jake's Avatar
mando jake
pics tommorow about dinner time.
