4x4 delay
Old Feb 1, 2008 | 02:11 PM
t/a for life's Avatar
t/a for life
4x4 delay
Hey guy's and gal's, I bought my first F-150. Its a 2004 FX4 extended cab.
I decided to install a leveling kit on the front end, and I accidentally knocked off one of the vacc. lines to the 4x4 solenoide. I put it back on and thought nothing of it, untill the next time I needed 4x4 high. Before the leveling kit, going from 2wd to 4x4 high only took about half a second to engauge, but after the leveling kit it seems like if I don't wait five seconds before pushing on the gas the truck will move forward and then a heavy clunk from the front side where I knocked off the vacc. line. What would cause the delay? Do I need to apply vacc. to the line before I install it back on the solenoide?
I appreciate all the help
Old Feb 3, 2008 | 07:46 PM
fordman19762003's Avatar
fordman19762003
you could have a small leak in the line which would cause enough of a loss in vacuum pressure make the axle slow to engage.
Old Feb 4, 2008 | 02:04 PM
damone's Avatar
damone
What would be the procedure to diagnose/fix this issue?
Old Feb 4, 2008 | 04:38 PM
fordman19762003
I'm not sure how to check for vacuum leaks, I've never had it happen to me,I've only heard it happen to other people and they usually took it to the dealer and didn't know how they fixed it. If it is a leaky line or fitting you just need to replace it. Maybe someone else here would know.
storchmj
22
Apr 6, 2014 05:59 PM
CamaroAdam73
15
Jan 10, 2012 03:55 PM
Morticar
1997 - 2003 F150
Sep 25, 2011 12:02 AM
Domestic_Nuwbee
Apr 10, 2011 04:26 PM
Mel Nash
Oct 15, 2004 08:00 PM
