1985 F150 engine idle problem
Old Oct 14, 2004 | 09:51 PM
Mel Nash's Avatar
Mel Nash
I'm new to this site so bear with me if I'm not in the right spot with this E mail.
I have purchased a 1985 F150 2wheel drive 4.9lt six cyl. with carb. standard 4 speed trans.I have been trying to solve a rough idle problem for about a week now.Here is what I have done so far with the engine.
1.Rebuilt carb.
2.Installed new intake and exhaust gasket.
3.Compression test all 150 psi +
4.Checked all vacc. lines and hoses
5.New spark plugs,wires,coil,dist cap and rotor
6.Checked timing good 10 deg BTC
7.Replaced EGR valve
8.Replaced O2 sensor
9.Replaced fuel filter
10.Blanked off vacc. line to brake power booster checked ok
11.Checked choke stove pipe ok
12.Tried high test gas no change
13.New PCV valve
Is there anything else I can try?
I have also checked the routing of the vacc. lines as per the emmission sticker.That part looks fine but ther are other vacc lines I,m not sure if there are hoocked up correct and the Haynes book I have does not show this.Has anyone out ther have a drawing that might help?
Regards Mel Nash
Old Oct 15, 2004 | 12:53 AM
locknkey's Avatar
locknkey
leaking carb to manifold gasket is a possiblity, have you check useing carb cleaner to see if engine rises when sprayed around carb manifold gasket?
Old Oct 15, 2004 | 03:28 AM
srercrcr's Avatar
srercrcr
If you'll write out your email address I'll send you a nice diagram of the vacuum lines for an 83 4.9, probably the same, maybe a slight tweak.
I'm suspecting the carb, not all rebuilds are alike.
Old Oct 15, 2004 | 08:00 PM
Mel Nash's Avatar
Mel Nash
thanks for the quick responce to my E mail.You can send any diagram of the vacc lines to mel.nash@sympatico .ca Also I have installed a new carb to manifold gasket and there is no leak there
Thanks Mel Nash
storchmj
22
Apr 6, 2014 05:59 PM
CamaroAdam73
15
Jan 10, 2012 03:55 PM
Morticar
1997 - 2003 F150
Sep 25, 2011 12:02 AM
Domestic_Nuwbee
Apr 10, 2011 04:26 PM
sean19
Sep 30, 2010 11:35 AM
