Detroit Iron CD
Old Feb 1, 2008 | 07:08 AM
jowilker's Avatar
jowilker
Detroit Iron CD
I have a copy of Factory Shop Manual, 1966 Ford Truck that I have had for several years, pre XP.
Anyone know how to load it on the hard drive and run it from the hard drive so that I don't have to keep the disc in the CD to use it.
thanks
John
Old Feb 1, 2008 | 08:52 AM
garbz2's Avatar
garbz2
John Typically Detroits discs are write protected and wont transfer... So you have to insert the disk just like MS streets and trips or other read only software.
Garbz
Old Feb 1, 2008 | 11:49 AM
jowilker's Avatar
jowilker
What a PITA, gotta be a way to defeat that. I have been reading how to make slip stream XP install disc with SP2, interesting what you can do.
John
Old Feb 1, 2008 | 11:56 AM
seventyseven250's Avatar
seventyseven250
if you figure out how, let me know. I'm really bad for scratching my CD's, and I don't want to loose the data, or have to buy the CD again.
Old Feb 1, 2008 | 02:21 PM
jowilker's Avatar
jowilker
I just burned a copy, and when I pulled it and re-inserted it the install screen came up. I stopped there.
What I would like to do is copy it to the hard drive or on a second drive and not have to load the darn thing every time I want to answer a question here.
I just installed a new hard drive and don't have the program loaded yet.
John
Old Feb 2, 2008 | 03:58 AM
Primered 1966 f100's Avatar
Primered 1966 f100
I have the same cd jo. You can save the files. I guess you could save every file. Just go through each one and save it. FILE/SAVEAS
Old Feb 2, 2008 | 04:58 AM
jowilker's Avatar
jowilker
Thanks, saving it isn't the issue, I want to run the program from the hard drive not the cd drive. Tying up the cd drive or having to keep the cd handy is what I am trying to avoid. I have 60 gigs of free space, so that aspect isn't a problem.
John
Old Feb 2, 2008 | 12:48 PM
jav409's Avatar
jav409
Originally Posted by jowilker
Thanks, saving it isn't the issue, I want to run the program from the hard drive not the cd drive. Tying up the cd drive or having to keep the cd handy is what I am trying to avoid. I have 60 gigs of free space, so that aspect isn't a problem.John
After you have copyed all the files one of them will be the exacutabull, just make a shortcut to it on the desktop.
Old Feb 2, 2008 | 03:59 PM
jowilker's Avatar
jowilker
Jav, Have you been able to pull it off?
John
Old Feb 2, 2008 | 04:27 PM
jav409's Avatar
jav409
Not with that program but several others , I have that program for my 66, when i get home monday ill try it and let you know how it works.
Old Feb 3, 2008 | 08:21 AM
jowilker's Avatar
jowilker
Would you click my user name and send me an email when you do, and we wont clutter up the forum in case it goes long.
John
Old Feb 6, 2008 | 06:51 PM
jav409's Avatar
jav409
Ok I was able to use it but it took a little work, all you need to do is make a folder on what ever drive you want I did it on the C drive, I named the folder Detroit iron, I then copied the Docs file to That folder. Then I copied the Power point viewer and ran the program and made a quick Icon on my desktop. I click on the Icon go to file, then to open, then go to the Detroit iron link open doc's and all the files are there. That's the easy part. Now for the fun part. Print a copy of all the files in the doc's file, and then open them one at a time and write down what the files are like the FOT55G1 file is actually Vehicle Identification. After you have a name for every file then just right click on the file click rename and rename it I named it Truck ID .When your done you will have an easy access to any page any time, you can then burn this file to a CD for future using.
Old Feb 6, 2008 | 07:50 PM
PROSTOCK's Avatar
PROSTOCK
John, now there's a man you owe a beer at least!!!(if it works)
Old Feb 6, 2008 | 08:51 PM
jav409's Avatar
jav409
Its more work up front but in the end you will have a database you can look up any time. IM about half way through naming the files. You know it's kinda dumb to copy protect a disk where all the files are easily accessed. Yeah it's gonna take a bit of time to rename the files, and you have to use the Pwpoint program to view them but heck it ain’t that much work. Most of the time you can make an execute command copy and it will be coded for the C drive. Not this little jewel. I have a folder called 66F100 for all my electrical diagrams, trany info, adapters etc… I have downloaded over the last couple of years. I just put the Detroit Iron folder in that Folder. I like to keep things together.
It’s not exactly running like the disk but it does work.
Old Feb 7, 2008 | 05:30 AM
jowilker's Avatar
jowilker
I know that I am dense, thick skulled, whatever, but have a question.
Why can't you put a small hard drive in your computer, copy everything from the CD to that drive, and install the program from the new small hard drive to the C:\ drive?
When you click on the icon it should reference the small hard drive like it would the CD drive. YES/NO???
John
