Oil Pumps
Old Aug 22, 2001 | 10:06 PM
georgedavila's Avatar
georgedavila
Oil Pumps
Milodon lists Hi-Volume/Hi-Pressure oil pumps with a press-on pickup tube for standard 429/460 applications and a dual inlet unit with bolt-on pickup for the SCJ.
I've always used the press-on unit and was wondering if someone can tell me if the SCJ model can be used in my front-sump econoline pan.
Old Aug 23, 2001 | 07:19 AM
DeenHylton's Avatar
DeenHylton
Oil Pumps
If anyone out there has a SCJ pan and could measure the depth of the sump, Georgedavila could then compare it to the depth of the van pan. A standard 429-460 oil pump for a rear sump pan has a 90 degree inlet for the pick-up tube, while a CJ/SCJ front sump oil pump has an inlet that's around a 45 degree angle.
As an alternative you can always tack weld the push-in style oil pick-up to the pump for "piece of mind".
Deen Hylton
Ford F250 460 C-6, K&N, Headers, Dual Exh.,Comp. Cams,Shift Kit
Pioneer CD w/Bose Speakers.
Other Passion: Blown 77 Corvette (Sorry Guys/Gals)
How I can afford to Drive the above: 93 GEO Metro
Old Aug 23, 2001 | 02:11 PM
Fordzzzz77's Avatar
Fordzzzz77
Oil Pumps
I don't have a Cobra Jet pan but I have a pan for a boat application using the CJ dual inlet pump. The front of the pan is 8 5/16 inchs deep and tapper back to 7 5/8 inchs. Hope this helps.
Fordzzzz77
Old Aug 23, 2001 | 08:10 PM
bandit99's Avatar
bandit99
Oil Pumps
FordTrucksKickGM
15
Oct 31, 2008 04:03 PM
490SCJ
Missouri Chapter
Feb 4, 2005 11:27 AM
trinogt
Jan 29, 2003 08:12 AM
mfunk
Aug 29, 2000 09:34 PM
