Passenger Side Valve Cover
Old Jan 31, 2008 | 10:04 PM
aocabrown's Avatar
aocabrown
Ok..for those with experience.
I'm about to change gaskets, UVC harness and glow plugs. I've been in the drivers side VC before (only issue was the far back bolt...PITA). Never been in the passenger side. Any gotchas? Anything 'extra' I have to take off on that side that might slow me down. Trying to plan out my strategy.
Old Jan 31, 2008 | 10:07 PM
8tsixt's Avatar
8tsixt
It's pretty straight forward. Nothing hard that i remember.
Old Jan 31, 2008 | 10:21 PM
bdrummonds's Avatar
bdrummonds
Just to give you more room, remove the AIH/GPR relay bracket, take of A/C compressor(not required) and set to the side, other than that its pretty straight forward.
OBTW you do know the gaskets are reusable, right?
Old Jan 31, 2008 | 10:40 PM
nhill2090's Avatar
nhill2090
be careful with the oil dipstick tube
Old Jan 31, 2008 | 10:46 PM
clintbonnie's Avatar
clintbonnie
I tied the heater hoses out of the way without removing them.. Also i found a 1/4" socket wrench with a swival and entension worked pretty good to get the bottom bolts out..I also built a wood platform to stand on. I also remove the A/C but like Brandon says, it really not necessary but gives you move room.. It comes off pretty easy..
Old Jan 31, 2008 | 11:05 PM
nhill2090's Avatar
nhill2090
clint reminded me, i think its easiest to remove the lower VC bolts on the pass side through the fender well using a wrench, the back 3 that is
Old Jan 31, 2008 | 11:11 PM
Tenn01PSD350's Avatar
Tenn01PSD350
You can unscrew the oil filler tube but I did not. I did not remove the AC or bracket. You must be very careful with the dipstick tube lest you have trouble and spring a leak at the side of the pan. Do not do this. PB blast the dual nuts/bolt. Other than that, remove what may be in the way. GPR and AIH relay stayed put for me. No problem there.
Did you know both Vcs can be removed without removing the CAC tubes? Just disconnect at the turbo and manipulate. It can be easier to simply remove them though. Gives you more room and much easier.
vf150
1997 - 2003 F150
Aug 9, 2013 02:33 PM
LOOnatic
May 10, 2013 10:13 PM
AndeyHall
Nov 11, 2011 05:30 PM
BigBlue92
Apr 22, 2011 04:38 PM
78broncoman
41
Jul 18, 2004 10:53 AM
