Engine Knock?
Old Jan 31, 2008 | 09:32 PM
Stroker4Life's Avatar
Stroker4Life
Engine Knock?
I have a 99 7.3 with 180,000 miles on it. Western diesel 3 stage chip, 4 inch exhaust, aftermarket injectors, not sure which ones. It has began to knock, worse when its cold at start up. Then steadys out when it warms up. Not real loud, but is noticable. A long shot, but if anybody can help me out I would appreciate it. Thanks
Old Jan 31, 2008 | 09:36 PM
MTDewX's Avatar
MTDewX
I had a knock once, and it turned out to be a bad injector (but that was my truck). ran like crap one day, then had to milk it to the shop. would not go over like 25 mph. good luck.
Old Jan 31, 2008 | 10:53 PM
Stroker4Life
I am hoping it is an injector. What if it is? Takem out and let the diesel shop put them on a flow bench? Or I guess I will have to contact them and see what their procedure is.
Old Feb 2, 2008 | 08:45 AM
Stroker4Life
Hello hello!!!!!
Old Feb 2, 2008 | 09:41 AM
dryfly's Avatar
dryfly
I have a bit of a knock every once in a while.So I'm interested in seeing how to diagnose this.Consider this a bump.
Old Feb 2, 2008 | 09:57 AM
PaysonPSD's Avatar
PaysonPSD
Start by testing your UCV harness for continuity. The GPs have nothing to do with knock but are on the same connector.
Old Feb 2, 2008 | 10:15 AM
clux's Avatar
clux
I agree with PaysonPSD, at 180,000 miles I would go ahead and replace the UVC harness. New harnesses solved similar symptoms for me.
Old Feb 2, 2008 | 11:02 AM
PaysonPSD's Avatar
PaysonPSD
Here's a pic of the UVC Connector. Hope this helps. If continuity test is bad you will have to remove valve cover and check that connector under valve cover is fully seated and also look for frayed wires or loose connections. If you get this far ,as Clux said, you might as well put in a new UVC harness.
Old Feb 2, 2008 | 12:18 PM
dryfly's Avatar
dryfly
What if your harness all checks out and you still get an intermiten knock.I wouldnt think it be a bearing going south if its intermiten.So would you think it could be a injector then?
and do those two problems sound similar?
Sorry
Old Feb 2, 2008 | 12:27 PM
PaysonPSD's Avatar
PaysonPSD
With the right test equipment a buzz test of the injectors and a cylinder contribution test would be the next step. A search on either will find some good info.
Old Feb 2, 2008 | 12:54 PM
dryfly's Avatar
dryfly
Thanks for the info.
