need a lower stance
Old Jan 31, 2008 | 09:28 PM
quicklilpony's Avatar
quicklilpony
need a lower stance
I am looking to drop my 58. What is the most cost effective way of doing so? will post pics later.
Old Jan 31, 2008 | 09:40 PM
quicklilpony
My 58 Custom Cab Styleside
Old Jan 31, 2008 | 10:23 PM
CIAF's Avatar
CIAF
The most cost effective on that truck is to leave as is. It look really great as is IMO.
Jon
Old Jan 31, 2008 | 10:47 PM
going slow's Avatar
going slow
if its leafsprings u could use drop blocks...those are pretty cheep and they work pretty good.. if u have some ponys pushing it id sugest using the steel ones not the aluminum ones .on the rear u can use drop shackles also...
Old Jan 31, 2008 | 10:50 PM
Goobzilla's Avatar
Goobzilla
Remove a couple leaf springs front and rear. Drop you a little bit and soften up your ride a little. But I agree with CIAF, looks great as-is.
Old Feb 1, 2008 | 03:54 AM
low54's Avatar
low54
leaf removal...every other one..per Midfifty's specs
Old Feb 1, 2008 | 04:09 AM
55 f350's Avatar
55 f350
leaves or the removal as said above . i keep entertaining the notion to do it to my bessie {53} and havent . i still use it as a truck and the potholes in illinois roads will eat it alive . although the roads in michigan were much worse the last time i was there ...................
Old Feb 1, 2008 | 07:38 AM
quicklilpony
Thanks guys. What about the drop axle for the front and flipping the axle in the rear? and there again I dont want to spend a fortune.
Old Feb 1, 2008 | 07:50 AM
low54's Avatar
low54
If you flip the rear you will need to "C" notch the frame...A drop axel is a nice approach if you wish to keep the straight axel...Add some short stacks from midfifty and you'll have a nice ride...cost about $900.00 to rework the front
Old Feb 1, 2008 | 10:46 AM
quicklilpony
Ill be happy when it is a bit lower w/ some smoothies and tires. Thanks for the info I just called midfifty. They are going to try and get me hooked-up.
Old Feb 1, 2008 | 11:17 AM
bobbytnm's Avatar
bobbytnm
Roast em' if you got 'em
Personally, I love the stance. The truck looks awesome.
The cheapest and easiest way woule be to remove every other leaf in the leaf springs. Thats where I'd start. Drop axles are pricey, flipping the rear will necessitate a "C" notch in the frame (probably) and a clearance hump in the bed floor
Good luck with it.
Bobby
Old Feb 1, 2008 | 12:01 PM
eman92082's Avatar
eman92082
No Bobby.... I think you already showed us the easiest way last week
Old Feb 1, 2008 | 12:48 PM
quicklilpony
Thanks low54. The midfifties people were great. They dont carry anything for my year. But they did give me the contact to Warner spring who does. I will be calling them tonight.
Thanks to everyone for the compliments. It's been a work in process for a while now. I am currently working on the interior. Bench recovered, stero, door panels, etc. I will post pics of the bench. I think it turned out pretty good.
As everyone is sayin, I may just remove a couple of leafs. How bad is it going to make the ride?
Old Feb 1, 2008 | 01:27 PM
bobbytnm's Avatar
bobbytnm
Here's how I lowered my 49;
Hopefully I'll have it fixed this weekend
Bobby
Old Feb 1, 2008 | 10:41 PM
CIAF's Avatar
CIAF
Bobby, you really need to post a pic of the truck from side with the "new" drop front so we can check out the stance.
Jon
Apr 13, 2004 12:08 AM
Nov 12, 2002 01:38 AM
Jan 14, 2002 09:06 AM
Mar 11, 2001 10:13 PM
