Help ICP sensor installed now wont start...
Is there any way to trick this PCM to thinking the IPR is working? I dont know if it only has 2 values, open and closed or if it meters....I know with an egr you can plug one in detached from vehichleto make it think it is installed. that way it opens and closes off the truck.
Thanks 3000 and everyone....
Plugged in IPR again.....after wiggling the connector doubt the connector whip from truck was bad....after rotating the cylinder where connector attaches...after tapping on it...after wiggling all connections at the control thing on top of the right valve cover...after whiggling the ground post
With the ICP disconnected but installed...and the connector for the icp cit off and the wires hanging out of the hood
the truck showed
code 2285 Inj contr pressure reg low? or something along those lines...I cleared...reset..same thing....the 2623 went away...reset..then
started...3 surges and then ran idle ok so far?
So now what...Ford couldnt find the wire harness on the computer....IDIOT
I will look for the part number on ebay and tell FORD!..but do I reconnect the old harness or leave it...drive it to auction or one of those buy quick places...and ditch the nightmare?
Im afraid to hook up the ICP! Still dont know why it says IPR low 2285 and why I had the 2623?
Ideas?
Ran after pulling, twisting, hitting harnesses, IPR...etc..ICP disconnected..
Idled then died within a few minutes...like before...
Only code 2285...Inj Pressor sensor low...low cause it is disconnecte?
Where did the 2623 go?
Ok now I am going to rig upmy own harness and reconnect
Truck showed 2285 code ICP sensor low....Old code from before when I had it disconnected.
Cleared code...truck showed NO codes now....2285 gone 2623 went somewhere..dont know how I got that to stop coming up..
Truck started...idled good...little rough run for a second..now idling as we speak
I am nervous to go drive it. If it doesnt die soon like before...I will try
Can anyone tell me what happened here from the info I have posted?
Seriously?
It runs like it did when I took it to ford before doing anything...and I have replaced the ICP....
So could it be that injector issue..#3 and 8 sticking cold?
When it gets hot it dies so this makes no sense...
I had no codes when i took it to ford...so
Did they misdiagnose?
So not sure where ford got #3 and #8.....
But to sum....ford said ICP...and 3 and 8 inj
NO CODES
I replaced ICP
then got 2623 IPR OPEN...
Disconnected ICP connector...
then got 2285...ICP sensor low
Wiggled and twisted...everythign gone...ran...but died like it did before with ford.
So either the icp was just leaking but working (since new didnt change its performance).....and it needed the injectors...
or the IPR was missed completely by Ford and it was causing it to die like it does erratically..starts runs, heats dies, let sit start run again then die..overnight, start fine...then die (wouldnt inj performance be more consistantly bad-unless they were passing sediment throught them at intervals- which is unlikely)
So I will let the shop know your thoughts 3000! it may be the IPR....
but why would it not set a code until I was messing around, then not again and the truck drove somewhat?
What were your symptoms...the scenereo.
Thxs
Good thing about this forum...you have a diary of events and then ultimately some solution...and people can see it. I found nothing similar though in my search. Mostly HPOP, EGRs, INJ..and that stuff
So they say INJ #1 and Ford said #3 #8 sticking Cold..... plus ICP
I replaced ICP...
SO now what do I do....#1 Or 3 and 8...1,3,8, or 1-8!
I cant see how 1 INJ not working...he says dead...would allow the truck to run when cold...warm up 5 minutes..then die....then wait 10..it will drive a little.
He says 1 inj could be stealing the oil pressure dropping it down on the whole bak. But wouldnt it drop it from the get go? Why the inconsistancy. Makes no sense. i asked about IPR..he said pressure was fine.
Im Confused. Dont want to buy $2400 in inj and have the same problem like when I did the ICp
ANY HELP? I'd appreciate further Ideas
Thxs
I do not know how bad INJ work...I mean can they be intermittent..or do they just go out. I know 7 cyl on a gas engine would run bad all the time..not when hot...this sounds like something else....Funny thing is they said the IPR was fine. I am gonna get the truck back and ask you guys how to check the IPR again for clarification.
Not sure how to OHm the thing out..
I tried diconnecting the ICP..>Ran the same really
